AlanM Posted May 2, 2006 Share Posted May 2, 2006 I know it will vary from car to car but any ideas how much fuel is left in the Supra when the warning light starts to come on? Quote Link to comment Share on other sites More sharing options...
edd_t Posted May 2, 2006 Share Posted May 2, 2006 isnt it something massive like 16ltrs or so? enough to get you at least 2 miles to the next optiflop fill up station... Quote Link to comment Share on other sites More sharing options...
veilsideTT Posted May 2, 2006 Share Posted May 2, 2006 my fuel light seems to come on early just above the first notch before the red. It goes out and i can go another 5-10 miles and then it comes on costantly when its about to hit the red. Very strange but ive read on here before that this is how it works. like a pre-warning or something Quote Link to comment Share on other sites More sharing options...
Guest hot soup Posted May 2, 2006 Share Posted May 2, 2006 I know it will vary from car to car but any ideas how much fuel is left in the Supra when the warning light starts to come on? i reckon its about 20 litres but its not something i intend to prove Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted May 2, 2006 Share Posted May 2, 2006 its approx 30miles when it comes on if you are driving normally and not heavy footed. Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 2, 2006 Share Posted May 2, 2006 I got the needle directly on the last white line the other day and it took 60.5 litres to fill up, so just under 10 litres left which equals 40 miles minimum if you stay off boost. The light came on well before this, it usually comes on somewhere between 18 and 14 litres. You can get the needle to the midpoint of the letter E and then you find out J-specs have a 70 litre tank and not and 80 litre one as was thought all those years ago... -Ian Quote Link to comment Share on other sites More sharing options...
Daston Posted May 3, 2006 Share Posted May 3, 2006 Wow J-spec has 10l less?? Another score for the J-spec for weight reduction Quote Link to comment Share on other sites More sharing options...
lockys96 Posted May 3, 2006 Share Posted May 3, 2006 yeh, j-specs are clearly better, ones which come with uk brakes,lol Quote Link to comment Share on other sites More sharing options...
Suprash Posted May 3, 2006 Share Posted May 3, 2006 I got the needle directly on the last white line the other day and it took 60.5 litres to fill up, so just under 10 litres left which equals 40 miles minimum if you stay off boost. The light came on well before this, it usually comes on somewhere between 18 and 14 litres. You can get the needle to the midpoint of the letter E and then you find out J-specs have a 70 litre tank and not and 80 litre one as was thought all those years ago... -Ian I have had my needle pointing below the last white line before when I got caught short, that was a worrying time............... Quote Link to comment Share on other sites More sharing options...
AlanM Posted May 3, 2006 Author Share Posted May 3, 2006 OK, thanks guys, I will try not to find out for definate either Quote Link to comment Share on other sites More sharing options...
