tbourner Posted May 2, 2006 Share Posted May 2, 2006 If it's randomly started and wasn't resulting from a mod, then reset the ECU and do some various driving styles, different revs, idle, hard accel, etc. to learn it! Quote Link to comment Share on other sites More sharing options...
super_supra Posted May 2, 2006 Author Share Posted May 2, 2006 just reset the ecu now got to go work so i ll see how it goes but i ll just take it steady till i get my AFR gauge and i can see whats happening with the fueling Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted May 2, 2006 Share Posted May 2, 2006 i was told you did, hmmmm glad i havent bought one now i would of been done out of £100 odd quid !! Thorin is right you dont need one..... but its advisable if your current one is getting on a bit Quote Link to comment Share on other sites More sharing options...
bignum Posted May 2, 2006 Share Posted May 2, 2006 mine does exactly the same when i use optimax, i noted where in the rev range it happened and got it down to thor, at the same revs it showed up a rich spot in the map and apparently uks are known for this?, so it could be what yours is, ide get it checked to be on the safe side tho. Quote Link to comment Share on other sites More sharing options...
