AJI Posted April 30, 2006 Share Posted April 30, 2006 Well as the title says, I attempted a full change of pads and discs today... it looks like an easy job to do.... that being remove pins from callipers, slide out the pads , take off the callipers, remove the discs and then slide on new discs, slide in new pads and redo all the bolts/pins etc. estimated time 3 hours. 5 hours later .... as with all car mechanical jobs that I try myself it seems I have to come across the biggest pain in the ar$e bolts you've ever seen. The pins for one thing take an imense amount of effort to even start to move, the calliper bolts are unbelieveably tight and don't budge one millimeter, and on top of that I've now got two cut fingers, a bad back and a black and blue thumb. Nice day weather wise in which I could have been out and about in my Supra, but no, my bright idea of "hmmm... think I'll save a couple of quid here, I'll do this myself"... sees me pi$$ed off, with only one new disc in place.... only the rear pads changed and now having to phone up my local garage to get them to finish off what I started. I could only get the left hand side calliper bolts to come free, and I could only get the rear brake pins to come free. Everything else was on tighter than a scotsman's purse strings ! Hope the garage have better luck. Link to comment Share on other sites More sharing options...
Tom S Posted April 30, 2006 Share Posted April 30, 2006 sorry just had to laugh, I just pay and smile now.... Link to comment Share on other sites More sharing options...
SimonB Posted April 30, 2006 Share Posted April 30, 2006 I've been there! Had to do exactly the same thing when I changed my front discs, one of the caliper bolts on the passenger side I couldn't budge and I was starting to round it off so I had to change the driver side disc and pads back again and take it down the garage! Then I went out a bought a great big breaker bar from Halfords for next time! Sometimes you just can't get enough leverage without it being up on a ramp. Link to comment Share on other sites More sharing options...
DannoSupra Posted April 30, 2006 Share Posted April 30, 2006 Similar Problem last week for me,, One of the pins on the back calliper woudn't come, ended up mushrooming the pin, snaping it off and out, and then buying a new one from toyota. NOW I GOT A NASTY BRAKE SQUEAK IN REVERSE! I need to have a proper look at my handbrake drums. leans to one side nose up on a hill with handbrake on! Link to comment Share on other sites More sharing options...
merckx Posted April 30, 2006 Share Posted April 30, 2006 I had to cut the heads off the pins and knock them out the other way. The caliper bolts were extremely tight aswell! You're right about the leverage, there's hardly enough room for a lever unless it's on a ramp. Link to comment Share on other sites More sharing options...
JohnA Posted April 30, 2006 Share Posted April 30, 2006 The caliper pins can be very hard to get off. If they haven't been treated with copper grease they sometimes need to be pressed out. Bastids. Link to comment Share on other sites More sharing options...
AntD Posted May 1, 2006 Share Posted May 1, 2006 Been there,done that.Now still got the rears to go,but a little voice is telling me to rather take it to a garage:D It doesn't beat the satisfaction of having had the job done by yourself though:) Link to comment Share on other sites More sharing options...
RobSheffield Posted May 1, 2006 Share Posted May 1, 2006 I always find bolts on my car fairly easy to remove. Granted a breaker bar is often needed. Fact is its an import that has been in the UK a year, and driven perhaps 5 or 6 hundred miles, and rarely in the rain and is fully waxoyled Link to comment Share on other sites More sharing options...
Darragh Posted May 1, 2006 Share Posted May 1, 2006 well on the up side of things once youve broke the nuts off when u go back to do it then itll be easyier to do as they will only be hand tight:cool: Link to comment Share on other sites More sharing options...
j80leo Posted May 1, 2006 Share Posted May 1, 2006 i always use two spanners together one on the bolt and the other around the open end of the spanner more leaverage so easy this way;) Link to comment Share on other sites More sharing options...
JohnA Posted May 1, 2006 Share Posted May 1, 2006 UK ones are a nightmare, with salts and all. Link to comment Share on other sites More sharing options...
Need4Speed Posted May 1, 2006 Share Posted May 1, 2006 To get the pins out, cut them in half then you've only got half the resistance to deal with at once. It's easier if you take the caliper off, remove the disc then refit the caliper to hold it while you cut with a junior hacksaw. Even if you get the pins out in one piece it's a good idea to replace them. To get the caliper bolts off use a 17mm socket with an 18" breaker bar. Link to comment Share on other sites More sharing options...
JohnA Posted May 1, 2006 Share Posted May 1, 2006 ...and don't forget to retighten them at the correct torque value. Pretty tight it is, too. Link to comment Share on other sites More sharing options...
psymon Posted May 1, 2006 Share Posted May 1, 2006 My misses just stated thats what we get when we buy old knackers Cheeky Sod !!!! :D Been in the same boat my self too lol Hope you get it sorted Link to comment Share on other sites More sharing options...
Darragh Posted May 1, 2006 Share Posted May 1, 2006 plenty of wd40:D Link to comment Share on other sites More sharing options...
ManwithSupra Posted May 2, 2006 Share Posted May 2, 2006 Use WD40 an hour or two before then the bolts will come off easier Link to comment Share on other sites More sharing options...
