Whitesupraboy2 Posted April 30, 2006 Share Posted April 30, 2006 ok i changed my plugs today on my NA and whilst i was looking at the intake i noticed a trail of Oil (pic attached) whats this mean? Also when i took throttle body and part of manifold off, the 2nd half of throttle body that joins the block, had a thick layer of Oil with loads of crap stuck to it, like a sludge, not pile of it just a light covering. And more then shown in the pic at the throttle body. We are talking a dark brown sludge cant see no metal through. Also look at the spark plug that is out of cylinder number 6 what would of cause that? Quote Link to comment Share on other sites More sharing options...
Jake Posted April 30, 2006 Share Posted April 30, 2006 look at the spark plug that is out of cylinder number 6 what would of cause that?A very clumsy person Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted April 30, 2006 Author Share Posted April 30, 2006 A very clumsy person hey ill have you know it didnt touch the sides when it came out I just find it weird thats it at such an angle that the tip isnt over the point? also the gap was about 0.01 mm Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted April 30, 2006 Share Posted April 30, 2006 The plug is f*cked, I suppose excess heat may have caused it to deform like that, or some fool dropped it when it was fitted. I take it from the pictures that you cars an NA, if so then have you got an aftermarket air filter on it? Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted April 30, 2006 Author Share Posted April 30, 2006 yes an NA and the intake is Standard. One thing i did find is there is bracket that holds top pipe off air box to body and the plastic arm to bolt to car had snapped off leaving a whole about the size of a box of matches, but being mostly covered as it was still sitting on the arm (if that makes sense) fixed it now by attaching the arm and its mount back over the hole Only thing i can think of is its come from that pipe you see....thats a cam cover breather i think?!? Quote Link to comment Share on other sites More sharing options...
b_have Posted April 30, 2006 Share Posted April 30, 2006 Plug is a bit worrying James, I would check the compression on that pot. If the plug came out like that, something has impacted it (heat won't deform it) Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted April 30, 2006 Author Share Posted April 30, 2006 Plug is a bit worrying James' date=' I would check the compression on that pot. If the plug came out like that, something has impacted it (heat won't deform it)[/quote'] How the hell i check the compression lol I thought id also just add, that performance is still just perfect hence why im puzzled. Quote Link to comment Share on other sites More sharing options...
b_have Posted April 30, 2006 Share Posted April 30, 2006 I have a compression tester you can borrow. Do it here if you want Monkeyman Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted April 30, 2006 Author Share Posted April 30, 2006 I have a compression tester you can borrow. Do it here if you want Monkeyman seeing as i aint got a clue what id do with it, if you did give it to me....at yours sounds like a plan! Just drop me a PM mate if ya know when u might be free and we can give it a test. Cheers James AKA the man who took 4 hours to change spark plugs Quote Link to comment Share on other sites More sharing options...
b_have Posted April 30, 2006 Share Posted April 30, 2006 PM'd Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted April 30, 2006 Author Share Posted April 30, 2006 replied Quote Link to comment Share on other sites More sharing options...
Guest Draven Posted July 3, 2006 Share Posted July 3, 2006 can I ask what the result of this was? my engine has just had the same thing happen to one of its spark plugs, so I'm very curious! Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted July 3, 2006 Author Share Posted July 3, 2006 the oil is because of crankcase pressure release and it works via vacuum so gets some oil into the air intake. My car has done a 120k miles so there will be some build up,so just cleaned it up. The spark plug...never found out what happened Quote Link to comment Share on other sites More sharing options...
normore1 Posted July 3, 2006 Share Posted July 3, 2006 Oil is as noted due to crakcase pressure. Replace the PCV valve. Plug is either due to mishandling during fitting or something in the cylinder impacted it (not good). As suggested do a compression check. Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted July 3, 2006 Author Share Posted July 3, 2006 yep we did compression check and mine was on the ball Like i said fine since PCV valve...whats this and where is it? Quote Link to comment Share on other sites More sharing options...
Robert Posted July 3, 2006 Share Posted July 3, 2006 Ah just admit you dropped the plug james Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted July 3, 2006 Author Share Posted July 3, 2006 Ah just admit you dropped the plug james that plug was in the car when i got it Quote Link to comment Share on other sites More sharing options...
Robert Posted July 3, 2006 Share Posted July 3, 2006 still rather blame you though Quote Link to comment Share on other sites More sharing options...
