Alloy/width/supra question
Getrag
Quicky...
Will the following alloy look too narrow/set-in on the back of a Supra
17, 40 offset, 8inch wide with 255 rubber?
Ok stock 17 inch wheel is, 9.5" wide 50mm offset, so 1.5" narrower. If the 8" had the same offset they'd be 0.75" (approx 19mm) further in the arch than stock 17's. As they have a 40mm offset, 10mm of the 19mm will be offset by this, so that the wheels will 'only' be 9mm further into the arch than stock 17's. Thats my understanding!!
I think most consider stock 17's in to the arch too much and these will look worse...........
ok that in english :badidea:
