Ian C Posted April 26, 2006 Share Posted April 26, 2006 Right, I've got an SPA dual gauge that reads fuel pressure and oil temp. I had the oil temp sensor part of it measuring underbonnet temps for a while but finally fitted it to a sandwich plate a couple of weeks ago. It was very useful in giving me indication of climbing oil temps during a track day but kharked it halfway through the day - the gauge went back to reading -61degC which is what it reads when the sensor isn't plugged in. The cabling was fine all the way up to the base of the sensor, I stripped and multimetered that to make sure. So I imagine something has broken inside the sensor. After it went wrong at the track day I got a reading on the gauge by bending the wiring right at the neck of the sensor, telling me a broken wire around that point. Bending the wire didn't last for long though, it's completely dead now So, with that bit of War and Peace out the way, can I simply swap the sensor for a generic one and wire it up to the perfectly OK wiring look I have, or will I have to get in touch with an SPA dealer for a whole new oil temp sensor and wiring and plug? I imagine option a) is going to be a multiple of times cheaper than option b) Piccy of the sensor attached, see if you can spot how far I could go testing the wiring If all oil temp sensors are the same, who can get me one...? -Ian Link to comment Share on other sites More sharing options...
uk-rich Posted April 26, 2006 Share Posted April 26, 2006 its a different design to my greddy one, so they may not all be the same Link to comment Share on other sites More sharing options...
SupraJames Posted April 26, 2006 Share Posted April 26, 2006 Funky Styling do sensors for all manner of gauges, just the sensors on their own, but im sure one of the traders on here could get you one cheaper. Link to comment Share on other sites More sharing options...
SimonB Posted April 26, 2006 Share Posted April 26, 2006 If you email SPA, you can buy a new sensor from them. I had to do this when I accidently knackered mine. I won't say how, it was embarrassing! Anyway, they sent me a new one, I can't remember how much it was, but it wasn't a lot. The guy I dealt with was called Tony Taylor, his email is [email protected], his phone no. is +44 (0) 1827 300150. Link to comment Share on other sites More sharing options...
Ian C Posted April 26, 2006 Author Share Posted April 26, 2006 You're a hero Simon, that's exactly the sort of info I'm after I'll let you know how I get on. -Ian Link to comment Share on other sites More sharing options...
Guest Terry S Posted April 27, 2006 Share Posted April 27, 2006 Ian I have a spare SPA oil temp sensor here if you can replace at some point? Link to comment Share on other sites More sharing options...
TRD3000GT Posted April 27, 2006 Share Posted April 27, 2006 My Blits oil temprature sesror has bugged out as well..Its the one that came with the BL Blitz Gauge I got quoted £90 for a new one.. Anyone got a better idea? Link to comment Share on other sites More sharing options...
