Here's Another One-cash Machines
nige
with the arrival of new drive through cash machines,customers will be able to withdraw cash,without leaving their car's.
please read wichever applies to you.
MALE CUSTOMERS.
1 drive up to the cash machine,2 lower your car window,3 insert card into machine enter PIN,4 enter ammount of cash required and withdraw, 5 retrieve card,cash,and receipt, 6 wind up window, 7 drive of.
FEMALE CUSTOMERS.
1 drive up to cash machine 2 reverse back the requierd amount to alighn car window to machine 3 restart the stalled engine 4 wind down the window 5 find handbag,remove all contents on to passenger seat to locate card 6 attempt to insert card into machine 7 open car door to allow easier access to machine due to its excessive distance from the car 8 insert card 9 insert card right way up 10 re enter handbag to find diary with PIN written on the inside back page 11 enter PIN 12 press cancel and re enter correct PIN 13 enter amount of cash required 14 remove cash and receipt 15 empty handbag again to locate purse and place cash inside 16 place receipt in back of cheque book 17 drive forwards two metres 18 reverse back to cash machine 19 retrieve card 20 restart stalled engine and pull off 21 drive for three to four moles 22 release hand brake.
Guest electricmini
Last time I was in Canada, I noticed a lot of the drive-thru cash machines
were far too high up on the wall for a normal car! So many people have SUVs
that the designers of the machines decided to put them in 4 feet off the ground.
So if you're in a normal car, or even a Supe, you're stuffed...
One near my friend's house is so bad, you can't even see the screen
unless you get out of the damned car :banghead:
Drive thru cash machines..... what a crazy idea!
(unless it's 30 below outside, then it's not such a crazy idea...)
