Ian C Posted April 26, 2006 Share Posted April 26, 2006 And clean up swarf Which is interesting on the stock setup My 850degC is a WOT from a standing start to over 180mph -Ian Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 26, 2006 Share Posted April 26, 2006 i put mine here just to be safe, i heard the stories of cracking probed too Is that a wideband lambda? if so have you ever had any overheat problems? Link to comment Share on other sites More sharing options...
SupraJames Posted April 26, 2006 Author Share Posted April 26, 2006 it takes no fitting really mate,drill a hole, tap it, screw in adaptor, fit probe ! sadly i dont have a tap, plus would not be totally happy about drilling holes in my manifold. I know a bit about engines, just not enough..! Link to comment Share on other sites More sharing options...
uk-rich Posted April 26, 2006 Share Posted April 26, 2006 Is that a wideband lambda? if so have you ever had any overheat problems? no,no overheating probs, was in the market for some new gauges and that was on my list since i went single Link to comment Share on other sites More sharing options...
Suprash Posted April 26, 2006 Share Posted April 26, 2006 if you get 780degC post turbo, is that safe or not...? So I guess from two stories we could say its not a common problem probably considering the amount of people running EGT's. Ian I would say 780 is just ok, + 200 (tops..) = 980, as I said I was told 150, so that would mean 930, I believe if your hitting the 1000 then things can start to melt........ Link to comment Share on other sites More sharing options...
Suprash Posted April 26, 2006 Share Posted April 26, 2006 With mine in the manifold I see approx 600deg on a 70lepton cruise and approx 700deg on a 100lepton cruise. Thats strange, when at 80mph mine reads 600 dead, and thats post turbo, your seeing 600 at 70 pre turbo..........??? Link to comment Share on other sites More sharing options...
Wez Posted April 26, 2006 Share Posted April 26, 2006 Thats strange, when at 80mph mine reads 600 dead, and thats post turbo, your seeing 600 at 70 pre turbo..........??? Would be interesting to know what your AFR is as mine is approx 14.7 - 14.3AFR, do you have any cats in place, are you still on stock tubbies? EDIT: just read your sig, you on hybrids with full decat. Link to comment Share on other sites More sharing options...
