EGT Sensor Fitting
SupraJames
Ok cheers, will speak with Rebas Systems as they have done a few bits on the car. Adding a few gauges, like oil temp and pressure at the same time, think I need one of those Greddy Oil Filter ring things, with the 3 outputs for gauges on it..! They are so pricey though..!!
I have put mine in the down pipe just under the turbos, as i'm not keen on the idea of the sensor failing and may well take out the turbine!:(
if you do want to fit the sensor into no1 or no6 exhaust runner, i would be inclined to take the whole lot off in order to do this, as swaf that is left in the runner or turbo is not a good thing! there are people that advocate drilling and tapping the runners whilst the engine is running i am also a rather dubious of this practice, as you cannot be sure that all of the swaf is expelled! and i certainly wouldn't want metal going through my turbos:(
I had mine in runner #1 when I got CW to fit it. The difference between #1 and #6 isn't that great. Having it after the turbo is a tad futile as you are sticking your finger in the wind to work out the temperature loss across the turbo.
CW has a special tool and a well-honed procedure to fit the probe without dismantling the turbos to pull the manifold. No swarf is introduced to the system.
-Ian
Not sure if there is any point putting the sensor in the down pipe, it will not give an acurate reading from that position...although it is a valid worry that it could break and damage the turbo whilst mounted in the exhaust runner.
Mine is in runner 6, and yes I like to live close to the edge :D :D
-Ian
Cheers Ian all sounds very good, sadly CW seems to be quite a way from me, not that I actually know where he is..! Will speak to a few people and see what they can do.!
I had mine put in the down pipe and I can appreciate peoples concerns about the temp obviously being out, but I have been told to add 150 to the down pipe temp to give you your rough manifold temp, and rough is close enough for me to see if my cyclinder temps are starting to knock on towards the 950 degree mark, thats all its there for, 2 guid me on whats going on. That out-weighed my decision at the time of fitting for pre or post turbo, but out of curiosity, how many EGT probs do we know of that have failed and caused turbine failure ??
I havent heard of a lot in just under 5 years, maybe one, so next time round I'd prob get it put in the manifold.............
I've heard of two going :shrug:
I also heard add 200degC onto the temps if it's post-turbo :) My old hybrid setup used to run 910degC absolute worst case scenario (30degC ambient temps, TOTB2, standing start to 170+mph top speed run) and that was measured in runner 1. It's nice to know that figure was accurate if you see what I mean - if you get 780degC post turbo, is that safe or not...? :blink:
-Ian
If you are that worried abot the tip failing (and it would only fail if it melted, and a melted tip usually means a melted piston), do as I do and buy Inconel probes and either use them with an existing "bling" gauge, or use an RS meter and buy a multi input one to read EGT and intake air temps on one meter. they are ugly though, but i always go for functionaility over bling. It MUST be near the exhaust valves, ideally in the combsution chamber isteslf, initial engine development is usually done with special plugs that can measure combustion temps and even instantaneous combustion pressures in each cylinder. After the turbo(s) is pointless.
I heard that occasionally they can shatter :shrug: With my tubular manifold I compromised and put the probe in the collector, positioned carefully so that if it did break it'd go through the wastegate rather than the turbo. It means the probe is 12" from the exhaust port though, but as I only see 850degC I'm not overly concerned :)
-Ian
