Install Question - Tein SS - Top Nut
veilsideTT
On the stock top mounts you can torque the top nut up when there installed.
On the Tein Coilovers with the top mounts, if you tried to torque the top nut up the center shaft would just turn with the nut so you cant torque it.
Are they torqued up from Tein when they come or is there a way to do this yourself when installed?
I wouldn't use an air gun then.... :) The only Teins I see are already scrappers, so I wouldn't get to see a manual for a new one. Doesn't the manual tell you how to lock the piston rod?
Normally done before you adjust the spring platform to push the spring upto the top mount. That's the way my HKS are done.
Usually a section on top of the strut to put a spanner, then tighten up the top nut.
Just done mine.
Stick the nut on. Tighten as far as you can go by hand. 17mm ring spanner and I used an adjustable to hold the shaft. The shaft has 2 flats. You can clearly see them as you screw the nut on... Torgue setting is a mere 27nm.
JOb done. Then start adjusting your ride height.
Si
