Dead Battery BLUES ! !
Steve W
Soop wouldn't start this morning ! ! !
Battery only enough to turn alarm off, but not
operate the remote locking ! !
Jumped from Dad's - OK
Stopped at Cafe (Sat' meeting place ritual !)
for ~40mins.... started OK
SO, at work, had an 005/4 delivered (the 'right'
Soop/Jap'size Battery) but had already bought
a bigger 097/4 weeks ago - in GARAGE ??
(005/4 = 380A/50Acapacity / 097/4 = 620A/60Acapacity)
Went to leave work.... click..click....
One of the lads turned round and came back,
jumped OK.
Had to cut ends of battery tray to accomodate
longer 097, and, 1/2" piece of wood under clamp
(Jap' batteries are shorter but taller ?????)
VROOOOOOOOOOM
....and the moral is... FOLLOW THE ADVICE
YOU GIVE TO ALL YOUR CUSTOMERS....
YOURSELF ! ! !
(ie. top it up BEFORE it needs it or it'll be too
late !)
ps. what probably killed it off was the run to
Lakeside Thursday night with all the Lights/
A'C'/Fan/.....and Ooopm-Dooompa on !
{it took the whole to/from trip to demist ALL
the windows properly ! - Soop sits unused
all week !)
FatS.
(pps. I have NO DOUBTS that the 005 is sufficient
if brand new ! ! ! - I just like a bit of an 'edge'
- plus the Soops' original sound system was a
teensy bit less demanding ! !:p )
YES mate, connectors are just 'NORMAL' round ones
ie. same as UK and same as Vauxhalls etc (and later Fords !)
Unless someone's already chopped/changed my terminals
over before I got it (look original ?) then Jap=UK=Vauxhall !?
UK is DEFINITELY just Vauxhall-size !!
size-wise, the 097 is ~1/2" less TALL so needs a block under the
clamp, but ~1" longer.
I looked all down the size/power list before I plumped for the 097 !
I reckon it's the "biggest-that-goes-in-with-least-adapting"
You'd prob' have to go up to one of the Hi-Fi ones next ??
(the VERY expensive, but, VERY powerful ones !?)
As I said, there's nothing wrong with the standard (005)
one ! I just like a bit extra (I had a Granada Heavy Duty on my
RS Escort ! !........ NEVER needed topping up..... EVER ! !)
FatS.
Tell you what... (ALL OF YOU ! !)
In the morning, I'll go 'measure' the + and - terminal diam's..
(too dark/cold/wet/LAZY now:D )
The +ve is slightly bigger than the -ve.
It'll have to be ruff "from-to" as they're 'conical' obviously !
let's get this sorted once and for all...
(I'll only be able to say what the 'Vaux/UK/MINE' size is, but if
"yours" is the same........................... )
Fingers crossed they're all the same ? cos it's MUCH easier if
the terminals aren't a worry.
(GBA3005 sounds awfully similar to 005 don't you think :conf: )
mmmmmm......... they look like they're NOT conical ???
(or is it just the piccy)
sizeish-wise they're bound to be the same..I reckon !
I let you know how "BIG MINE IS" tomorrow Thorie-Pooh.
(shame... there's now a nice new 005/4 Lucas Calcium 4-Year
battery in me garage ! ! ! :innocent: )
hi all
my battery was dead, crappy jap micra type.
just fitted new battery Exide Maxxima 900 Deep Cycle,
paid 165+vat direct from Exide UK 0161 786 3300 speak to Robb.
delivered within 48 hours, Pukka!! (they accept visa etc)
phoned around for prices was quoted between £250-£290.retail.
bits cut-out of Tray.....
(it's possible that if I'd ground/sliced the 'feet' off both ends it would
just about squeeze in the tray, but knowing my luck I'd grind/slice
thru the battery casing ! ! !...... the feet ARE just extra plastic
castings on the ends/sides)
[edit:- should have unbolted tray really - only 4 bolts - but raining
and no-one will see it anyhow....but, for that prof' touch.....!!]
