DannoSupra Posted April 21, 2006 Share Posted April 21, 2006 Mates jst got his 300 Back from the bodyshop after 3months, It runs like a bag of Sh*t!! It goes when on full throttle, but dawdling around it coughs and splutters! Thinkin Vac Leak.. any ideas? cheers Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted April 21, 2006 Share Posted April 21, 2006 yep check all hoses for leaks. if not talk to scott at http://www.redlineimports.co.uk he specialises in z's Quote Link to comment Share on other sites More sharing options...
D8MOA Posted April 21, 2006 Share Posted April 21, 2006 lol small world i no scott and graham at redline well and he does no about 300's hes had enough problems with his Quote Link to comment Share on other sites More sharing options...
absz Posted April 21, 2006 Share Posted April 21, 2006 i found the same problem on two z's now were the fuel injector connectors seem two make bad connections and theres green stuff growing in them , cleaned all connections and hey presto:) Quote Link to comment Share on other sites More sharing options...
Lucifer Posted April 21, 2006 Share Posted April 21, 2006 if you are aaround the bristol area my friend is azed specialist Quote Link to comment Share on other sites More sharing options...
mkirby Posted April 22, 2006 Share Posted April 22, 2006 Mates jst got his 300 Back from the bodyshop after 3months, It runs like a bag of Sh*t!! It goes when on full throttle, but dawdling around it coughs and splutters! Thinkin Vac Leak.. any ideas? cheers yeh check all the connectors on the ignition amp, CAS and MAF most likely is its not running on all cylinders so pull the connectors off each coilpack and you will hear the engine dip so plug it back in and do that for all 6 Also could be a dicky o2 sensor Quote Link to comment Share on other sites More sharing options...
