Correct tire PSI (Jab MKIV)
Bradb
Standard Jap Door sticker says 36 front and rear. For stock 16’s or  17’s
30 is too low,  steering will be heavy and the car will probably wallow in corners. Braking  performance could be reduced as well, tires will wear at the edges.
General consensus is between 34  to 36
I run 35 rear 34 front. Tire wear is pretty uniform at these levels.
It seems better. Its pi**ing down at mo, so not the best time to try it out. Although i couldn't resist trying the old classic "Foot down, back-end slide till Trac cont kicked in. Bizzarely it didn't and the car powered forward.
I'll be stupid then.
Thanks for the PSI advice, seems to have worked, but to whom should I send the bill for my new set of tires mid December? ;)
The  Supra  wears expensive  boots. So when you found  a good pressure match for you car, I would check it  weekly. It is also a good way  to spot a slow puncture.
I had a valve neck go at the seal with the  alloy,  1000 miles after fitment, I think it got a knock on a track day, I lost 5lb  in one week, then 2lb a day, then 10lbs on the day it went completely.
As the power steering is so strong  I did not feel the  difference until the day I lost  10 lbs.
I use an electronic gauge accurate to 0.5lb
