SimonB Posted May 14, 2006 Author Share Posted May 14, 2006 TLicense said: Good to hear it's going well mate! I see you've fitted a K&N filter on the idle air inlet valve. Do you have a part number for it and a good place that can supply them as I'll be needing one. Hope the mapping goes well! Cheers I got mine from Demon Tweeks, part no 62-1360, it was £18ish. Link to comment Share on other sites More sharing options...
wkdtime Posted May 14, 2006 Share Posted May 14, 2006 Good read, look forward to seeing what she puts down on the rollers, what sort of power are you expecting? and what boost are you running it at the moment mate? Link to comment Share on other sites More sharing options...
dandan Posted May 31, 2006 Share Posted May 31, 2006 Any more progress Simon? Link to comment Share on other sites More sharing options...
dandan Posted February 4, 2007 Share Posted February 4, 2007 .... ? Link to comment Share on other sites More sharing options...
SimonB Posted February 4, 2007 Author Share Posted February 4, 2007 Sorry, missed your last post! Let's see, what's happened since I last posted... Well, I had some real problems with the Emanage ultimate, I posted up a thread about it but something was wrong with it or the injector adaptor or something. I needed to swap it with someone else's or something to see what was up but I couldn't really do too many diagnostics as I need the car to get to work! So in the end I decided the best thing was to go for a standalone ECU based on future plans etc. So, I went for a Motec M600, had it installed and mapped at Owens, where it made 550bhp at 1.4BAR on their rollers. Setting the ignition timing correctly has made a huge difference, it feels superb. Not cheap though! I've got a couple of problems though, first I'm getting compressor surge in high gears and mid revs. It needs the compressor housing ported really. Second I'm getting some smoke on full boost, from burning oil. I think it's either the oil seal on the turbo, or possibly an oil control ring or something. Pretty sure the breathers and oil lines are ok. Anyway, I've decided to go for a slightly bigger turbo, so I've bought a T67DBB from Qaisar. I also snapped up Martin's built block and head, so I'll be swapping the engine, running it in and then switching turbo and getting it mapped at higher boost/revs. Link to comment Share on other sites More sharing options...
TLicense Posted February 4, 2007 Share Posted February 4, 2007 SimonB said: Anyway, I've decided to go for a slightly bigger turbo, so I've bought a T67DBB from Qaisar. I also snapped up Martin's built block and head, so I'll be swapping the engine, running it in and then switching turbo and getting it mapped at higher boost/revs. Ooooohhhhhhh! That block is something stunning! Would like to see that finally fitted into a car. Keep us informed! Link to comment Share on other sites More sharing options...
Ian C Posted February 5, 2007 Share Posted February 5, 2007 You'll be pleased to hear that the T67DBB is sized correctly for our engines and doesn't surge at all -Ian Link to comment Share on other sites More sharing options...
dandan Posted February 5, 2007 Share Posted February 5, 2007 I am jealous. Enough said.... Link to comment Share on other sites More sharing options...
mikeyb10supra Posted February 5, 2007 Share Posted February 5, 2007 Simon is Arnouts manifold able to flow enough air for the 67?? I was going for a GT35r on the cast mani similar to your setup but its interesting your now going for the 67....wil be interesting to see the spooling difference between your setup and a 67 on a tubular header Link to comment Share on other sites More sharing options...
SimonB Posted February 5, 2007 Author Share Posted February 5, 2007 mikeyb10supra said: Simon is Arnouts manifold able to flow enough air for the 67?? I was going for a GT35r on the cast mani similar to your setup but its interesting your now going for the 67....wil be interesting to see the spooling difference between your setup and a 67 on a tubular header Well, we'll find out! Don't see why not. Link to comment Share on other sites More sharing options...
mikeyb10supra Posted February 5, 2007 Share Posted February 5, 2007 SimonB said: Well, we'll find out! Don't see why not. Well thinking about it, its bigger than the turbonetics manifold so me neither to be honest, Im quite sure the spool will be quicker as well, think I will subscribe to this thread;) Link to comment Share on other sites More sharing options...
SimonB Posted March 27, 2007 Author Share Posted March 27, 2007 Time for a quick update, this is my car at the moment, can't help thinking there's something missing... Link to comment Share on other sites More sharing options...
SimonB Posted March 27, 2007 Author Share Posted March 27, 2007 Bits are currently being swapped over from my old engine to my shiny brand new built engine courtesy of Martin. It looks superb, I'll probably pop over there tomorrow and take some photos - I'm going to try the new turbo on for size as I have a feeling it may not fit at the moment. The compressor cover has a 3inch exit instead of 2.5 and I think it may well foul the manifold, in which case I'll have to get hold of another one. Link to comment Share on other sites More sharing options...
dandan Posted March 27, 2007 Share Posted March 27, 2007 Good stuff, keep us posted! Link to comment Share on other sites More sharing options...
Lucifer Posted March 27, 2007 Share Posted March 27, 2007 Where's that engine?!? Link to comment Share on other sites More sharing options...
SimonB Posted March 28, 2007 Author Share Posted March 28, 2007 Right, here we go, a couple more pics of the new engine. I went over today and test fitted the new turbo (PT67DBB) because as I said I thought it might foul the manifold but it fits fine, so that's going on now as well. May as well since I'll have to keep it off boost while running in anyway and then it'll be going up to Owens for remapping. It looks HUGE too Pretty much everything has been transferred over from the old engine now. Link to comment Share on other sites More sharing options...
mikeyb10supra Posted March 29, 2007 Share Posted March 29, 2007 Si whats the turbo attached too in that second pic, it looks like its floating in mid air are you still using this on a cast manifold? Link to comment Share on other sites More sharing options...
Ark Posted March 29, 2007 Share Posted March 29, 2007 Why does it need to go to Owens for mapping? Triton have a dynocell and are very competent. Link to comment Share on other sites More sharing options...
SimonB Posted March 29, 2007 Author Share Posted March 29, 2007 Ark said: Why does it need to go to Owens for mapping? Triton have a dynocell and are very competent. Because they are the Motec experts basically. Plus they mapped it originally and did a good job - they've mapped several Supras with Motecs so have good base maps etc. Link to comment Share on other sites More sharing options...
SimonB Posted March 29, 2007 Author Share Posted March 29, 2007 mikeyb10supra said: Si whats the turbo attached too in that second pic, it looks like its floating in mid air are you still using this on a cast manifold? Yeah, you can just see the manifold - it's gone a sort of brown colour with heat! The turbo was just stuck on to check it would fit, so the compressor outlet is not at the right angle, but it is attached to the manifold, honest Link to comment Share on other sites More sharing options...
dandan Posted June 6, 2007 Share Posted June 6, 2007 Any updates Simon? Link to comment Share on other sites More sharing options...
SimonB Posted June 8, 2007 Author Share Posted June 8, 2007 The new engine is well and truly run in (done 2500 miles on it now). It was booked in to be mapped a month or so back but I was still waiting on my fuel kit from Dusty so I had to postpone. I fitted the fuel kit last weekend, for which my tip is make sure you use the stock crush washers on the stock fuel filter fitting that goes to the rail or it will leak like a bastard! Anyway, it's going to be mapped on Monday, just in time as I'm going to Le Mans on Wednesday. I'll probably swap in my new Koyo rad and fans tomorrow. Then I'm just waiting on my cam covers with -12 fittings for the bigger breather system - I've got a catch tank and hose and fittings already. Link to comment Share on other sites More sharing options...
Alex Posted June 8, 2007 Share Posted June 8, 2007 SimonB said: The new engine is well and truly run in (done 2500 miles on it now). It was booked in to be mapped a month or so back but I was still waiting on my fuel kit from Dusty so I had to postpone. I fitted the fuel kit last weekend, for which my tip is make sure you use the stock crush washers on the stock fuel filter fitting that goes to the rail or it will leak like a bastard! Anyway, it's going to be mapped on Monday, just in time as I'm going to Le Mans on Wednesday. I'll probably swap in my new Koyo rad and fans tomorrow. Then I'm just waiting on my cam covers with -12 fittings for the bigger breather system - I've got a catch tank and hose and fittings already. I'd leave the stock cam covers on for the trip to LeMans....these #12 ones that don't have proper valves concern me in light of the Front Oil Seal Failure thread.... Glad to hear your new motor is working well at present. Long may it continue!!! Link to comment Share on other sites More sharing options...
SimonB Posted June 11, 2007 Author Share Posted June 11, 2007 Just back from Owen's, so the car is now mapped at last! 625BHP@6893rpm and 500lbft@6486 is what it made on the dyno. To say it's fast is a severe understatement, it's like a missile! Still got a few things to do, haven't fitting my new rad and fans yet, still haven't got round to fitting my Mocal power steering rad either. And I need to fab myself a front undertray, duct the rad/FMIC a bit better and tidy the intercooler pipework up a bit. Then I think I shall be off on a quick trip to Germany to see if I can make 200mph Link to comment Share on other sites More sharing options...
b_have Posted June 11, 2007 Share Posted June 11, 2007 Kettles on Link to comment Share on other sites More sharing options...
