Well oil be
Keith C
ONLY use Toyota's own oil.
I believe it's called V160 or similar.    (certainly the code for the Getrag box is V160 as per the VIN plate).
The only other possible oil that could be used is Dextron II (i think).
This has been discussed before and apparently if you use different oil it messes with the seals etc.   Chris Wilson i believe agrees with this too.
