Is This Bad???
Supra ST Myster
Its ok to drive, but you should get another one as soona s you can to avoid any costly problems, especially in this weather.
The dirt will stick to the piston and be forced through your seal, damaging both the seal and the piston (as it gauges it away). This will mean that your shock won't seal properly and you will have to get a new one. Or at least replace the seal if your lucky. Either way more expensive than replacing just the boot.
Hope this helps
Originally posted by Paul Laing
it should be replaced yes, might not go through an MOT being ripped. Plus think of all that salt and stuff going into the shock, nasty!
It will not fail a MOT on this, even if it's missing altogether. They are water and grit guards, I doubt it being damaged will shorten the life of the shock TOO much, but if you are fitting new shocks I'd suggest you go the extra mile and fit new bellows too. They ARE available separately from Toyota.
  • 3 weeks later...
Originally posted by supra TT myster
does anyone know how i go about fitting it?? Do i need to compress the spring to change this part?
Yep. You need to take the suspension leg off, compress the spring and then remove the top of the shock. It's an extremely dangerous job if you don't have the correct spring compressing equipment.
Originally posted by John Packham
Just go to your Toyota dealer and buy a new one. Actually buy two and do the other side as well. It's and exteremly easy job and you can't repair them. I think they're about £17 each but I may be wrong - didn't keep the bill.
So are we thinking of the same job then to change this part from what Jake has said or did you have all the tools to do it??
