Matt H Posted April 19, 2006 Author Share Posted April 19, 2006 O.k then so its defo not fuel cut.. so what could it be then?!?! Link to comment Share on other sites More sharing options...
ardasaliah Posted April 19, 2006 Share Posted April 19, 2006 If its not fuel cut it could be a misfire. if so you need new plugs- about £20 should sort you out with 6 NGK plugs. or a dodgy boost controller Link to comment Share on other sites More sharing options...
m_cozzy Posted April 19, 2006 Share Posted April 19, 2006 the hks evc iv on mine drops the boost to stock levels if it reaches the preset warning, set to 1 bar, warning was also 1 bar so when it exceeded this slightly it beeped away and cut boost, not sure what 'stock boost' is though. Same happens when it is set to high 1.2 bar with the warning at 1.2, if it slightly exceeds this then the boost will drop. Sound like the problem you have? Link to comment Share on other sites More sharing options...
Matt H Posted April 27, 2006 Author Share Posted April 27, 2006 Just established that i have a fuel cut defender (Blitz one) installed! So it defo carnt be fuel cut! Link to comment Share on other sites More sharing options...
wez_p Posted April 27, 2006 Share Posted April 27, 2006 does sound like a misfire fits the description, as if the plugs aren't sparking properly or fuel starvation? a visit to a decent rolling road who can measure your fuelling as it happens is an option? AwesomeGTI in Manchester were good last time we went. it'll cost you £60 to turn up & get a session with them or wait for a group day & it's about £35 (but they don't always measure fuelling on group days). If it's doing this even when your boost controller is switched off, it is possible you don't have a restrictor ring in the exhaust & so there's nothing stopping the boost going above what it should be doing? i remember Mr Wilson telling me that even if you have a boost controller you still need a restrictor ring Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 23, 2006 Share Posted June 23, 2006 I have new Thor FCD's here, we can try one if you like? i doubt it's that however. Link to comment Share on other sites More sharing options...
