DannoSupra Posted April 21, 2006 Author Share Posted April 21, 2006 Would my car overboost with no cats?? Quote Link to comment Share on other sites More sharing options...
Lucifer Posted April 21, 2006 Share Posted April 21, 2006 Yes. Quote Link to comment Share on other sites More sharing options...
Jake Posted April 21, 2006 Share Posted April 21, 2006 Would my car overboost with no cats?? Yes. Not if it's a UK spec Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted April 21, 2006 Author Share Posted April 21, 2006 Right, if i'm gonna get rid of the first Cat, what am i suppose to do? soz to be a pain, need to know these things incase she goes POP Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted April 21, 2006 Author Share Posted April 21, 2006 Depends. Not if it's a UK spec Why not if it's a UK? Quote Link to comment Share on other sites More sharing options...
Jake Posted April 21, 2006 Share Posted April 21, 2006 Better wastegate on the UK spec ones Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted April 21, 2006 Author Share Posted April 21, 2006 Better wastegate on the UK spec ones So no need to get a Restrictor ring? is that what their called? Also.... .... What boost would it run at? Quote Link to comment Share on other sites More sharing options...
Jake Posted April 21, 2006 Share Posted April 21, 2006 Do you have a UK spec then? If so then no you won't need a restrictor ring but you will need something to raise the boost. ie an EBC or manual bleed valve. I wouldn't over boost UK spec turbos too much though. They can't take it, despite what some UK groupies will tell you. J-spec ceramic turbos are usually fine to 1.1 or 1.2 bar. Some folks have run 1.3 for years with no problems. Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted April 21, 2006 Author Share Posted April 21, 2006 Do you have a UK spec then? If so then no you won't need a restrictor ring but you will need something to raise the boost. ie an EBC or manual bleed valve. I wouldn't over boost UK spec turbos too much though. They can't take it, despite what some UK groupies will tell you. J-spec ceramic turbos are usually fine to 1.1 or 1.2 bar. Some folks have run 1.3 for years with no problems. I've got an Apexi AVC'R fitted, wont that raise the boost? Quote Link to comment Share on other sites More sharing options...
JohnA Posted April 21, 2006 Share Posted April 21, 2006 Mine are now fixed at *cough* 1.5bar *cough* Been like that for a few months *spit* Quote Link to comment Share on other sites More sharing options...
Lucifer Posted April 21, 2006 Share Posted April 21, 2006 Mine are now fixed at *cough* 1.5bar *cough* Been like that for a few months *spit* Cool. Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted April 21, 2006 Author Share Posted April 21, 2006 i've been told not to go over 1.4! ah well ha ha Quote Link to comment Share on other sites More sharing options...
Jake Posted April 21, 2006 Share Posted April 21, 2006 I've got an Apexi AVC'R fitted, wont that raise the boost?Sorry, my crystal ball must be on the fritz tonight. Yes, your Apexi AVCR Boost Controller can be used to control your boost. Quote Link to comment Share on other sites More sharing options...
JohnA Posted April 21, 2006 Share Posted April 21, 2006 Before anyone tries to replicate blindly I must add: 1. I've got a spare set sitting in the garage, so I won't get depressed if they kick the bucket. 2. They don't compress pure air, but misty stuff. The compressors behave quite differently (although I can't say if it affects overspeeding at all. I'd need a shaft rpm gauge for that) 3. The cylinders do not see funny temperatures, mainly due to water/meth, so detonation is not an issue 4. The oil is always fresh synthetic, I am a bit anal on this one. Quote Link to comment Share on other sites More sharing options...
