Work completed this weekend
Wez
not a lot, wash, polish and wax, that's hard work enough for me lol...
and some total system cleaner in the full tank of fuel to clean the system out!
more exciting jobs to do over the forthcoming weekends :)
really enjoyed driving it though!
Installed a 2 gauge pillar pod housing Defis (Turbo and Oil Temp) wired in the controller, and wired in an AEM UEGO controller.
Busy boy on Friday, then spent the rest of the weekend doing family things, and went for a couple of blasts in the car trying to 'Teach' the ECU what it needed to know after the battery disconnect.
Mike
Hey Matt,
Did really well actually, but now have very sore dirty hands :-
* installed new fuel rail with 650cc inj
* installed stock fpr (removed pbv)
* complete front indicator mod
* installed hard pipe kit
* redo turbo hosing
* fix high idle on startup (no longer hitting 1900rpm)
* sorted out AFR at idle (14.5 - 14.7)
* installed new throttle body
Funnily enough when I replaced the PBV with the stock regulator it fixed my stumble from throttle tip in, it would appear that the PBV was dumping lots of fuel causing it to go silly rich and stumble.
:eyebrows:
drain oil
remove greddy oil pressure and temperature guage feeds
spent all of friday afternoon trying to remove the guage lines, that had been tiewrapped 139,456 times
refitted top glovebox
removed door cards and my crap speaker brackets
traced fault on pass speaker
removed dash and fitted defi guage lines
attempted removal of daft greddy oil filter relocation and 23row (stupidly big!)oil cooler
remind me to punish any japanenese guage fitter i EVER meet :D
well I completed a difficult 'bulb replacement' install to the rear cluster that's been annoying me for a while... and then after a couple of seconds observation in Halfrauds car park, I decided to replace the corresponding bulb on the other side, as one was now very marginally brighter than the other, even though it hadn't 'gone'.... ;)
Guest Terry S
not this weekend ( Friday before), but changed the cams and springs & retainers on the VVTi and now the frigging VVTi unit is having a fit. Hopefully its a bit of sh1te thats got in. I will do a thread on it when I have time.
Glad yours is coming along Wez.
twice, same car twice or two different cars? whats the job like? I imagine the box isn't the smallest and easiest to move around.
Pain in the arse springs to mind. Was on Steve's car (Black Cat). A retaining clip wasn't supplied with the clutch and wasn't noticed till on and everything put back :( Was really good to do as i learnt alot.
I started polishing some engine parts up. :) Bling bling here I come. :D
Isn't that surpose to read James and I?? :p
Well, I've started work on fitting my single. Changed the oil, and tackled the electronics. Pulled my Emanage and AEM wideband out and wired in my new Emanage ultimate & Innovate LC1 wideband in. Even with a Fields harness it took bloody ages. I never want to crimp another connector in my life!
Today I got all that stuff back in the car and it running, then tidied up the front of my garage, pulled the nose of the car in and started dismantling stuff. Got the bumper, and most of the intake side of the turbos off.
Why the change from the AEM wideband?
