RICHARDA Posted April 17, 2006 Share Posted April 17, 2006 Air con light was blinking away so thought it may need a regas however I did this at work today and the light is still blinking away. Anyone know what this means or could it indicate a number of things? Many thanks Rich Link to comment Share on other sites More sharing options...
Scooter Posted April 17, 2006 Share Posted April 17, 2006 I think the aircon light flashes when the aircon pulley to engine speed is out by a determined amount. It could indicate the aircon compressor is partially seizing. If you've got the right spanner/socket (14mm) you could remove the fan/aux belt and check the pulley. Link to comment Share on other sites More sharing options...
Scooter Posted April 17, 2006 Share Posted April 17, 2006 just been reading the manual, the seizing part could be a bit OTT on my part. Basically the system has a built in shut down of the aircon system (by turning off the compressor) if the ratio of the aircon pump to engine is too different. Does the inner part of the aircon pulley engauge when the aircon is turned on? Link to comment Share on other sites More sharing options...
Lucifer Posted April 17, 2006 Share Posted April 17, 2006 Got 2 good ones if it is teh case. V Cheap Link to comment Share on other sites More sharing options...
RICHARDA Posted April 17, 2006 Author Share Posted April 17, 2006 Thanks fellas I will check it out. Link to comment Share on other sites More sharing options...
RICHARDA Posted April 17, 2006 Author Share Posted April 17, 2006 Lucifer, how much is cheap? Link to comment Share on other sites More sharing options...
Lucifer Posted April 17, 2006 Share Posted April 17, 2006 £75 Link to comment Share on other sites More sharing options...
jaymdee Posted April 28, 2006 Share Posted April 28, 2006 Air con light was blinking away so thought it may need a regas however I did this at work today and the light is still blinking away. Anyone know what this means or could it indicate a number of things? Many thanks Rich Rich, Did you get this sorted as mine's started doing this. What was the problem. I've been assuming it was just needing a re-gas, not an actual problem. Any answers would be great. J Link to comment Share on other sites More sharing options...
RICHARDA Posted April 30, 2006 Author Share Posted April 30, 2006 No mate I have'nt had time to sort this yet. Ideally I'd like to get rid of the AC altogether as I rarely use it. Just read your post and mine seems the same, I switched the AC on whilst driving the other day and the belt squealed and slipped just as you described. Let me know how you get on. Cheers Rich Link to comment Share on other sites More sharing options...
jaymdee Posted April 30, 2006 Share Posted April 30, 2006 Damn, was hoping you could tell me. I'll probably get it re-gassed and see if that's it. I looked into the spyglass and saw nothing, so I think it's empty, maybe a leak? Link to comment Share on other sites More sharing options...
RICHARDA Posted May 1, 2006 Author Share Posted May 1, 2006 I too thought the blinking light meant a regas so I did this at work but the light still blinks, I think the air con pulley is the problem. Link to comment Share on other sites More sharing options...
