Car not moving when on reverse gear
Guest weather
Guest weather
Hi guys, having this problem with my auto box. Its a 95 tt uk spec. Cant reverse on the first start up but after the second time it will be ok.This problem started when i install the greddy bcc and greddy sld. Hope to get some positive advise, Thanks
E
Guest weather
Yes, my o/d light is flashing. Car seem to be in normal driving condition even when i push it hard. Will be going in the garage today. Hopefully the mech that install the greddy lsd will figure a way to solve it.
Guest weather
Its been 6 days since my mech disconnect the greddy sld. Everything seems ok with the reverse gear. Suspect its the wiring of the sld. Will connect it again to see whether the reverse gear will be ok. If nor then the instalation of the sld is wrong!!!!!
