mattanna Posted April 14, 2006 Share Posted April 14, 2006 Hi all even though i could not get my steering wheel off today, i WILL:( be doing it tomorrow, just a query about earthing. There is only one wire for horn on my non airbag steering wheel, attached are pics of momo horn and earth wire. Do i earth it by putting the steel ring around the base of the horn so it is touching the metal connector or do i use the earth wire, if so where does that go? Matt Quote Link to comment Share on other sites More sharing options...
Daston Posted April 14, 2006 Share Posted April 14, 2006 ah I had this prob when doing mine today, the earth is connected to the spring so no need to do that, however with mine I had to clean the black off the spring to get a good contact for it to work Quote Link to comment Share on other sites More sharing options...
mattanna Posted April 14, 2006 Author Share Posted April 14, 2006 No need to do what, i just need to know exactly where the spring or the wire goes? cheers Matt Quote Link to comment Share on other sites More sharing options...
Daston Posted April 14, 2006 Share Posted April 14, 2006 Ok you dont need to use the wire to earth it as the spring should be in contact with one of the copper plates (used a current meter thing to find out which one) all you need to do is connect the horn contact to the other copper part and bobs your uncle. Quote Link to comment Share on other sites More sharing options...
mattanna Posted April 14, 2006 Author Share Posted April 14, 2006 Thanks mate, have just sent you a pm but you can ignore it now!! cheers Matt Quote Link to comment Share on other sites More sharing options...
mattanna Posted April 14, 2006 Author Share Posted April 14, 2006 So i take it that the spring goes round the base of the horn and contacts the copper plate and when the horn is installed the spring contacts the metal part of the boss? Quote Link to comment Share on other sites More sharing options...
Daston Posted April 14, 2006 Share Posted April 14, 2006 ah sorry the spring I was refuring too is the one inside the horn unit (the one that springs the horn button back up) Quote Link to comment Share on other sites More sharing options...
