DannoSupra Posted April 14, 2006 Share Posted April 14, 2006 Is there different HKS FCD's for different vehcile's? reason im asking, i've seen a couple on ebay 2nd hand BUT it sais their for Skyline's or Nissan Fittments, 'Type H' ring any bells??? Cheers Quote Link to comment Share on other sites More sharing options...
chilli Posted April 14, 2006 Share Posted April 14, 2006 not sure but the recommended one is the thor vfcd and it's only a few quid, probably worth getting a decent one rather than saving a few pounds. the decent ones still keep a safety limit but raise it up by a controllable amount, some others just remove the safety limit altogether so you have no protection at all! Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted April 14, 2006 Share Posted April 14, 2006 And some will scale the MAP sensor output, meaning that you're fuelling will always be incorrect.... Get the Thor one. £70-80 IIRC Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted April 14, 2006 Author Share Posted April 14, 2006 will it work ok on mine, using MAF, its a uk Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted April 14, 2006 Share Posted April 14, 2006 Yes, as the UK car doesn't use the MAP sensor to control fuelling. The MAP sensor on a UK car is only used to activate fuel cut on overboost. Quote Link to comment Share on other sites More sharing options...
