cg084 Posted November 24, 2003 Share Posted November 24, 2003 Hi, After this mornings cold weeather. I had the misfortune of trying to get in the car. Well the side windows had frozen to the door seals. Is the a good treatment for the rubber to stop this happening. Also is there some king of wd40 type spray other than de-icer to spray in the locks to stop them sticking in the cold weather. I can remember seing stuff to do the job but cant remember where or even the name. Cheers. Link to comment Share on other sites More sharing options...
Terminator Posted November 24, 2003 Share Posted November 24, 2003 I am sure Chris Wilson has a solution to this, but can't remember what product he recommened. Don't put WD40 on the rubber. If you search door seals or something like that, you made find the old thread Link to comment Share on other sites More sharing options...
Marco Posted November 24, 2003 Share Posted November 24, 2003 A little trick you can do is push against the door. So it closes more. (I dont know how to describe it better ) Then the windows should come loose from the rubber Link to comment Share on other sites More sharing options...
far Posted November 25, 2003 Share Posted November 25, 2003 Also is there some king of wd40 type spray other than de-icer to spray in the locks to stop them sticking in the cold weather. My dad used to heat his key up with a lighter and then when he stuck it in the key hole it would melt any ice which had collected on the mechanism. I think having a keyless entry system on your alarm is the easiest option Link to comment Share on other sites More sharing options...
JamesG Posted November 25, 2003 Share Posted November 25, 2003 Originally posted by cg084 Hi, After this mornings cold weeather. I had the misfortune of trying to get in the car. Well the side windows had frozen to the door seals. Is the a good treatment for the rubber to stop this happening. I suffered from this a lot last year. Autoglym vinyl & rubber care may help a bit by keeping the rubber supple to stop the water getting in. I used to de-freeze my doors by tipping lukewarm water over the car. Don't do this! Water collects on top of the door sills and properly freezes the door shut. For quite a few days I had to climb in through the boot James. Link to comment Share on other sites More sharing options...
Marco Posted November 25, 2003 Share Posted November 25, 2003 Originally posted by JamesG ... For quite a few days I had to climb in through the boot James. LMAO Link to comment Share on other sites More sharing options...
Steve W2 Posted November 25, 2003 Share Posted November 25, 2003 Originally posted by JamesG For quite a few days I had to climb in through the boot James. HOW? Are you a midget? Are you talking about climbing through the Supra boot or a renault Espace? I would try buying new door selas to see if that helps, try rubbing grease into the seals, leaving it for a while, and then rubbing any excess off. This stops any water getting into the rubber and stops it freezing if it does. Link to comment Share on other sites More sharing options...
Toms Supra Posted November 25, 2003 Share Posted November 25, 2003 Wurth make a product for rubber seals which prevents freezing etc. Or use silicone spray and bumper gel which will stop it freezing. Link to comment Share on other sites More sharing options...
Paul Posted November 25, 2003 Share Posted November 25, 2003 Vaseline this, and many other uses Paul (where's me sheep gone?) Link to comment Share on other sites More sharing options...
Supra_Al Posted November 27, 2003 Share Posted November 27, 2003 Try using Holts rubber and nylon lubricant,it's in a spray can which costs around £4 from most motor shops, this works a treat! Al. Link to comment Share on other sites More sharing options...
MONKEYmark Posted November 27, 2003 Share Posted November 27, 2003 mine have been freezing shut too. normally start car up for 5 mins with remorte start to get it on its way to warming up. window was all iced over too. mate at work gave me a liter bottle of isoprople alchaol (spelling) he told me to use on window if they are frozen. its the same stuff you clean tape heads with. you can buy from chemist but they do the 20 questions on what you using it for and its exspensive. i get it from work. i use it for cleaning work surfaces clean and computer parts. i gave cw a couple of big coffee jars full of it. he was saying its what they put in that watter wetter for radiators. was wondering if it could be used as part of the water injection. i will try some on windows in morning see if it does anything to help Link to comment Share on other sites More sharing options...
Need4Speed Posted November 28, 2003 Share Posted November 28, 2003 you can buy from chemist but they do the 20 questions on what you using it for Nanny state! Tell them it's for cleaning "safety" cameras. You wouldn't drink it, Tesco Vodka's cheaper. Hey, why not use Tesco Vodka? It works on my Lada! Sorry, not a very technical comment I know. Link to comment Share on other sites More sharing options...
Branners Posted November 28, 2003 Share Posted November 28, 2003 Originally posted by Paul Vaseline this, and many other uses Paul (where's me sheep gone?) I suggested vaseline on the window rubbers last year and got told off, it will degrade the rubber. there are various products out there which are basically rubber lubricants which should be used. JB Link to comment Share on other sites More sharing options...
Paul Posted November 28, 2003 Share Posted November 28, 2003 I know WD40 degrades rubber, didn't know vaseline did? Oh well, I'll have to finish this large pot off on the sheep then:D Paul Link to comment Share on other sites More sharing options...
400BHP Posted November 28, 2003 Share Posted November 28, 2003 Vaseline does degrade rubber and latex, thats why you use KY! Use silicone grease (available from a plumbers merchant) this will work a treat and not damage the rubber, will also stop squeaky boot rubbers! As for putting isopropyl alchohol in my radiator, I don't think I would, as its very very volatile and I wouldn't think it would mix with water very well being of a much lighter specific gravity and density. Link to comment Share on other sites More sharing options...
400BHP Posted November 28, 2003 Share Posted November 28, 2003 Or get one of these Link to comment Share on other sites More sharing options...
