JohnK Posted April 11, 2006 Share Posted April 11, 2006 Has andone got a pic of a stock Rad from a TT auto and manual - out of the car please. Quote Link to comment Share on other sites More sharing options...
LeeT Posted April 11, 2006 Share Posted April 11, 2006 can i ask why john? the only difference is that the auto has two small pipes in the bottom for cooling the auto tranny fluid Quote Link to comment Share on other sites More sharing options...
JohnK Posted April 11, 2006 Author Share Posted April 11, 2006 one of my auto cooler pipes goes off to the side, I havent taken the bumber off so i cant see where it goes either. Was curious to that and also the size of the auto cooler section and weather it could be used for anything else, eg engine oil. Quote Link to comment Share on other sites More sharing options...
LeeT Posted April 11, 2006 Share Posted April 11, 2006 one of my auto cooler pipes goes off to the side, I havent taken the bumber off so i cant see where it goes either. Was curious to that and also the size of the auto cooler section and weather it could be used for anything else, eg engine oil. the one that goes off to the side goes to a cooling rad in the passenger side air duct. i wouldn't bother using the coolant radiator for engine oil but maybe the rad in the air duct Quote Link to comment Share on other sites More sharing options...
JohnK Posted April 11, 2006 Author Share Posted April 11, 2006 now for the silly question, if 1 pipe from the autobox goes to the bottom of the main rad, the other to a little rad at the side, where are the returns? Quote Link to comment Share on other sites More sharing options...
LeeT Posted April 11, 2006 Share Posted April 11, 2006 now for the silly question, if 1 pipe from the autobox goes to the bottom of the main rad, the other to a little rad at the side, where are the returns? iirc. there are two pipes (feed and return) run along side the engine under your turbo, the feed pipe goes to the coolant rad then back out through the oil rad then returns back to the auto box via the hard pipes under your turbo. i hope you get that, im not very good at explaining things:D Quote Link to comment Share on other sites More sharing options...
JohnK Posted April 11, 2006 Author Share Posted April 11, 2006 ahh there is a connection I cant see between the 2 rads. Quote Link to comment Share on other sites More sharing options...
