Steviegeeza Posted April 11, 2006 Share Posted April 11, 2006 1993.5 Jap Supra MKIV TT auto 90K miles. The overdrive off indicator occasionally flashes 1 in 4 seconds after the car has been going quick! The box is working fine - smooth changes at the right time (best auto I've ever driven). I assume this must be the auto ECU trying to tell me somthing - Anyone know what it is ? Thanks Steve Quote Link to comment Share on other sites More sharing options...
Steviegeeza Posted April 11, 2006 Author Share Posted April 11, 2006 Should have searched first Poor quality speed signal convertor causes the flashing OD off light, and I have seen the flashing spoiler light, another symptom. Who's convertor delimiter is deemed to be best by this illustrious group? Steve Quote Link to comment Share on other sites More sharing options...
Ian C Posted April 11, 2006 Share Posted April 11, 2006 Thor Racing, find them in the trader's section with all their contact details -Ian Quote Link to comment Share on other sites More sharing options...
jamesmark Posted April 11, 2006 Share Posted April 11, 2006 mines done that, is your slip control button flashing too? one on one off, i aint at home but there is 2 faults for this, not 1 there is a fault code chart on here somewhere touch wood mines has not done it in a while Quote Link to comment Share on other sites More sharing options...
Shaun. Posted April 11, 2006 Share Posted April 11, 2006 JAMESMARK !!! Can you enlighten me / us on this as mine has just started to do this since i put my dash back together, that is , overdrive is flashing and Trac off is flashing. It seemed ok yesterday morning but by the afternoon was back again. Many thanks mate. Shaun. Quote Link to comment Share on other sites More sharing options...
veilsideTT Posted April 11, 2006 Share Posted April 11, 2006 Mine does this too. Apparently it can be the connections inside your odometer. Pete at thor recommended soldering a wire onto the speed sensor signal (going into the unit) onto the speed sensor wire (going out of the unit). Creating a bypass if you get me Supposidly thats were the signal breaks down and causes the O/D light to flash (code 42 usually - speed sensor) HTH Quote Link to comment Share on other sites More sharing options...
jamesmark Posted April 11, 2006 Share Posted April 11, 2006 ok i have found what is at home on here mines was fault code 89, when my o/d and slip button flashed hope this helps Quote Link to comment Share on other sites More sharing options...
jamesmark Posted April 11, 2006 Share Posted April 11, 2006 on top of that i have never found how to fix it as no matter how i drive the car (hard or not hard) in all weather it has not come back touch wood Quote Link to comment Share on other sites More sharing options...
CardiffSupra Posted April 11, 2006 Share Posted April 11, 2006 Read this fella, http://www.mkivsupra.net/vbb/showthread.php?t=57157&highlight=o%2Fd I did this and my od has stopped flashing also stopped my engine management light coming on and slip cont flashing Good luck fella Quote Link to comment Share on other sites More sharing options...
veilsideTT Posted April 11, 2006 Share Posted April 11, 2006 When it says "connect the pink to the blue/red wire" does that mean literally cut and disconect the pink wire from the unit and connect it to the blue/red? or just splice the pink wire onto the blue/red leaving the pink still attached to the connector also? Read this fella, http://www.mkivsupra.net/vbb/showthread.php?t=57157&highlight=o%2Fd I did this and my od has stopped flashing also stopped my engine management light coming on and slip cont flashing Good luck fella Quote Link to comment Share on other sites More sharing options...
Shaun. Posted April 11, 2006 Share Posted April 11, 2006 Thanks guys, some good info here. I'll take a look this weekend and see if I can cure my problem. Shaun. Quote Link to comment Share on other sites More sharing options...
mark newman Posted January 1, 2009 Share Posted January 1, 2009 Hi did you get your problem sorted out with the flashing over drive light. as i have the same and i would like to no what to do thanks mark Quote Link to comment Share on other sites More sharing options...
Zohain Posted October 3, 2021 Share Posted October 3, 2021 Can someone help my over drive and traction light flashing I was reading to you by pass pink wire onto red/blue but when I opened my dash I couldn’t see any ...has anyone got video how to do it please Quote Link to comment Share on other sites More sharing options...
tayr Posted October 4, 2021 Share Posted October 4, 2021 10 hours ago, Zohain said: Can someone help my over drive and traction light flashing I was reading to you by pass pink wire onto red/blue but when I opened my dash I couldn’t see any ...has anyone got video how to do it please cant help with the wiring but when i had this issue it was the trac ecu that needed replacing.. opened it up and the circuit board had leaked Quote Link to comment Share on other sites More sharing options...
