Boost Problem
SupraJames
Ok last week my car went in to have both the turbo side and inlet side stripped to replace missing bolts and bolts not done up fully from a previous job, was all put back together with new gaskets, seals, etc etc, now when it went it was running 375 bhp at the hub @ 1.2 Bar boost. All put back together and was test run, first turbo comes in and as starts boosting it seems to be leaking and the boost drops, you can hear it leaking as well, and the second turbo does not even come in. Was stripped again today and both actuators checked and all ok. Any ideas what and where could be leaking to cause this prob, on the dyno it only made 5 psi boost..! please help.
thanks
Guest gzaerojon
its a long shot but were all gaskets definatly removed before new ones fitted?
maybe one could be doubled up with an old gasket.
And the normal check all pipes ect especially jubilee clips as i had a few knackerd ones when i removed mine.
also i have a black rubber hose split on the turbo hard pipes, it split between one of the ridges, looked like it had gone brittle
im no expert of course but its worth a try :)
I'm not so up on turbo engines yet, but I remember reading a post on here when I first got my car, about a guy that was getting low boost the second turbo was doing nothing, it sounds similar to your faults described, his was simply a leak from the BOV.
Sorry if this is a bit noobish, I just thought I'd try and help.
Ok update, BOV is fine, all VSV's are apparently fine also, so back to square one..! Could my boost controller being causing this..? it was all set up and working fine. Am going to collect the car on Friday, fixed or not fixed. Dont suppose there is any Supra Gurus around Surrey that could help me, as I cant afford to pay some one else to sort it out again..!
You can hear it leaking you say.
So something might be loose, cracked or misplaced.
For example, some cracks look OK to the eye, and only open up under pressure.
My bet is something was not put back together properly.
Mine is also UKSpec, so you are welcome to put them side by side and check for discrepancies, if it helps.
M25J4, if it's any good.
