Hit a wall last night....
DannoSupra
You'll probably need a new wing and certainly a new headlight! Main thing to check is that the bonnet isn't damaged or twisted.
I had similar damage a while ago, but found both the upper and lower front sub assembly's needed changing. That made a big difference to the cost.
thats why i chose to replace it, i dont want a cake of body bodge on the side of my car
BTW i know they will pull most of the dint (or should i say crater) out first
I used to work for Toyota, in portbury.. Ude be suprised how much filler is in a NEW car!! Tiny bit more in the wing? who cares.. A decent body shop would knock it out so much hardly any filler would be used anyway..
Why add 150 for a wing, + labour, fitting, spraying just to say that wing has no filler! But then thats IMO
Its your car dude :)
