ttc + hks evc 4
m_cozzy
Hi, I have a quick question. I have recently bought a TT and whilst checking it over the other night for the mot on monday I have discovered that it has been converted to ttc. The car also has a hks evc mk4 valve controller fitted, I vaguely remember reading somewhere these dont like to run with sequential turbo's?
The previous owner was unaware of this modification, the car runs extremely well as it is but I kind of think I would like to swap it back to sequential.
Any suggestions, swap it back & risk messing it up or just keep driving it as is?
I dont think its just the HKS controller, I have got prob with my Greddy Profec, im running sequential tubs, and it seems to only want to control the first one. Was advised to do a TTC and see if it worked any better. I would stick with the TTC.
Which GReddy Profec do you have James? It should work, are you sure it is connected up correctly?
  • 6 years later...
I use to have the EVC IV on mine in sequential mode and it worked fine. It was a few years ago, but vaguely remember I had to set it up manually, rather than use the learning mode.
There are set up instructions here if you need them.
http://www.racecarnewmedia.co.uk/hks/pdf/evc/EVCIVsetup.pdf
Gonna be doing this soon to my 93 JDM TT. Can you give me setup info for the HKS EVC 5 Nic and maybe a little tutorial on how to install it?
