Stolichnya Posted April 7, 2006 Share Posted April 7, 2006 Hello, posted this B4 but in wrong section i think. Anyhew, when the car is cold or warm, i get a real shudder/vibration form the rear under mediocre boost (wont do full boost when cold of course) its more from the left rear side but oddly, when its hot and gone thru full boost once or twice its not doing it! It does it every time its stared from cold but when hot, no sign at all! HEEEEEEEEEELLLPPP I am driving to Luxembourg in it next Thur and want to get it sorted . thax for any help all Link to comment Share on other sites More sharing options...
Ian W Posted April 7, 2006 Share Posted April 7, 2006 good luck mate, hope you manage to sort it as i've had a vibration problem with my n/a for the past year......still not sorted and it's going to see it's third mechanic very soon Link to comment Share on other sites More sharing options...
Ian W Posted April 7, 2006 Share Posted April 7, 2006 did you manage to get your brakes sorted out btw? Link to comment Share on other sites More sharing options...
Stolichnya Posted April 7, 2006 Author Share Posted April 7, 2006 hi, yes brakes all sorted and being fitted on Tues. Had the top hose leak this morn, blew coolant all over my engine! nice mess Link to comment Share on other sites More sharing options...
Ian W Posted April 7, 2006 Share Posted April 7, 2006 any luck with the vibration problem? am hoping you might be able to point me in the right direction Link to comment Share on other sites More sharing options...
Stolichnya Posted April 7, 2006 Author Share Posted April 7, 2006 not one reply! i posted this on other forum too and no answers at all, do you have the same thing? damn odd, only does it when cold/cool/warm buit once i have rtidden thru it for 1st time on boost it does not do it again! leave it for few hours to go cold and there it is again! it may be the exhaust rubbing (but dont think so) until its hot. only started doing it 2 weeks ago but it is really a bad shudder/vibration, it resonate thru the car and is very auduable Link to comment Share on other sites More sharing options...
Ian W Posted April 7, 2006 Share Posted April 7, 2006 mine isn't quite the same (being an n/a) and mine does it intermittently whether hot or cold but it IS a bad vibration and enough to point the car in a different direction if i wasn't to correct it (not tramlining, either). Link to comment Share on other sites More sharing options...
Stolichnya Posted April 7, 2006 Author Share Posted April 7, 2006 its a bugger! am off to luxembourg next thur in the soop and want it sorted, my luck the dff will explode or something! fully intend to do the E411 (road) at 170+ so need a pukka motor, want to see if i can get it flat Link to comment Share on other sites More sharing options...
Ian W Posted April 7, 2006 Share Posted April 7, 2006 good luck anyway, mate. let me know if you manage to sort it. Link to comment Share on other sites More sharing options...
Stolichnya Posted April 7, 2006 Author Share Posted April 7, 2006 will do. TTFN Link to comment Share on other sites More sharing options...
merckx Posted April 7, 2006 Share Posted April 7, 2006 Might be the exhaust if you haven't got a standard one. Has it been doing this since you got the car or fitted an exhaust. On my Nur Spec R the back box wil drop a little when it warms up due to the hanging rubbers stretching a little when warm. Think I would check this first to make sure it's not catching. Link to comment Share on other sites More sharing options...
Ian W Posted April 7, 2006 Share Posted April 7, 2006 could be the problem on Stolichnya's car but mine has been doing it before i got my exhaust mine's been checked by 2 mechanics already but no luck.....if the next one can't turn anything up it's a trip to CW!! Link to comment Share on other sites More sharing options...
Stolichnya Posted April 7, 2006 Author Share Posted April 7, 2006 Hi Mercx I had thought this might be it but the exhaust has been on for 6 months and the problem has only been about for 2 weeks. It really feels like the rear left wheel but as it only does it when cold it cant be, this is what is stumping me. The exhuast i have is a no-CAT complete custom made one, it has been running fine till 2 weeks ago. could it be the diff low on oil until its worked round and warm, no eveident leak there tho.. Gear box oil low? its a pain Link to comment Share on other sites More sharing options...
merckx Posted April 7, 2006 Share Posted April 7, 2006 Definately worth replacing the diff oil if you're on a trip to Luxembourg. Link to comment Share on other sites More sharing options...
Stolichnya Posted April 10, 2006 Author Share Posted April 10, 2006 i think i may have a solution or answer to this. if the supra has a limited slip diff, i have been told that the "clutches" inside and if the shim's are worn slightly or a bit then they will cause a shudder until they are warm and expanded. The shudder is caused by the shims/clutches not doing what they do properly until they have expnaded enough to take up the missing slack! Does this sound feasable or a good explanation? Link to comment Share on other sites More sharing options...
Ian W Posted April 10, 2006 Share Posted April 10, 2006 hmmmm, according to my vin plate i shouldn't have an LSD. i suppose one could have been retrofitted though. is the only way to check to get the back wheels in the air then? Link to comment Share on other sites More sharing options...
Stolichnya Posted April 10, 2006 Author Share Posted April 10, 2006 will keep everyone (looking) updated as its in right now for a water leak, new fast road pads and a look into the shudder. Ther bloke said it was the most likekly reason. i thought it had an LSD as std but i know nothing about these things. new oil going in diff as a precaution anyway. Most important thing is the water leak. i just had a new water pump fitted and its laking afetr 2 weeks!! Link to comment Share on other sites More sharing options...
suprattgaz Posted April 10, 2006 Share Posted April 10, 2006 Does it do it straight?? If so it ain't the diff. Is it the bracked attached to the clutch holding the exhaust? That can fracture but not be visible until dismantled. Link to comment Share on other sites More sharing options...
Ian W Posted April 10, 2006 Share Posted April 10, 2006 mine is an auto and does it in a straight line, yes. dunno if stolichnya's car is an auto or manual though. Link to comment Share on other sites More sharing options...
Stolichnya Posted April 11, 2006 Author Share Posted April 11, 2006 Hia, back again! Mine is a 97 Manual TT 6spd RZ with about 400bhp. I had a chat with the garage last night and he had been in touch with someone for a chat re this and was told that if the Diff is emptied, slushed out and re-filled it should cure the problem! fingers crossed. He ssaid its the shims inside worn a tad and not doing what they should until warm/hot, which would explain why it only does it once when you open it up a tad. I dunno. Odd how it can be this on a 43,000 mile old car! Am also having huge problems with a water pump leaking too, its only juyst been fitted and its p*****ing all over. Hope its done today as only have until Thursday to test before i set off for Luxembourg in the Supe! EVERYTHING CROSSED Link to comment Share on other sites More sharing options...
Ian W Posted April 11, 2006 Share Posted April 11, 2006 I had a chat with the garage last night and he had been in touch with someone for a chat re this and was told that if the Diff is emptied, slushed out and re-filled it should cure the problem! fingers crossed. He ssaid its the shims inside worn a tad and not doing what they should until warm/hot, which would explain why it only does it once when you open it up a tad. I dunno. Odd how it can be this on a 43,000 mile old car! when you say the shims inside would that only be in an LSD or would it effect an open diff as well? (as you can tell i know bugger all about diffs!!) Link to comment Share on other sites More sharing options...
Stolichnya Posted April 11, 2006 Author Share Posted April 11, 2006 i dont know myself - i just assumed they hd an LSD! i will let you know if i am the proud owner of an LSD or not later.... hopefully if i get the car back today. I tell ya, a 1.2 Corsa is doing nothing for my cred! paper bag anyone? Am also thinking about the RTLC traction thingymajig, std traction cont is about as much use as a fart in a space suit! email add is [email protected] as i cant have this open all this time, email me if want to cont chat re this Link to comment Share on other sites More sharing options...
Ian W Posted April 11, 2006 Share Posted April 11, 2006 email sent Link to comment Share on other sites More sharing options...
