Is my Car BPU ?
ManwithSupra
most of the traders on here will have what you want, or place an add in the wanted section, mmm think i may have a fcd kicking about but i would be suprised if you didnt have one fitted already as your catts are out, read the faq section or searh bpu every thing you need to know is there
How Would i tell if it had a FCD.
When i was repalcing a fuse the other day i noticed a small switch on a lead down where the fuse box was on the drivers side of the car. Now i dont know what this does would this be a switch for a FCD i know its a shot in the dark but hey.
If i needed to find out if it had one where most likely would i look?
me personaly bpu i would go to 1.1bar with a restrictor ring save on the boost controller 1.2 on ceramic turbos is risky but people do but should,nt need remapping
Boost controller allows you run 1bar daily with the option to high mode for 1.2, safer again I would have thought !
