Jake Posted April 7, 2006 Share Posted April 7, 2006 The washers that come with ARP head studs are too big to fit into the bolt holes in a VVTi cylinder head! And I've lost half the washers that were on the original Toyota head bolts. GRRRRR!!!! Nothing's ever simple, is it? Link to comment Share on other sites More sharing options...
Alex Posted April 7, 2006 Share Posted April 7, 2006 Jake + engine = Hope you sort it... Link to comment Share on other sites More sharing options...
Rich Posted April 7, 2006 Share Posted April 7, 2006 The washers that come with ARP head studs are too big to fit into the bolt holes in a VVTi cylinder head! And I've lost half the washers that were on the original Toyota head bolts. GRRRRR!!!! Nothing's ever simple, is it? itll all be worth it when its finished,a good learning experience! Link to comment Share on other sites More sharing options...
Nic Posted April 7, 2006 Share Posted April 7, 2006 That probably doesn't help does it Link to comment Share on other sites More sharing options...
Tom S Posted April 7, 2006 Share Posted April 7, 2006 Jake + Fixing = Great!! Apart for Door Cards of course !! Link to comment Share on other sites More sharing options...
Jake Posted April 7, 2006 Author Share Posted April 7, 2006 OK I figured it out in the end. You need to drop the washers sideways down the hole and then maneuver then into position with a screwdriver or somesuch implement BUT you have to remove the stud from the block before dropping the washer into the head. Once the washers are in place you simply pass the stud through the washer and head into the block. Easy when you know how innit! Link to comment Share on other sites More sharing options...
Lucifer Posted April 7, 2006 Share Posted April 7, 2006 OK I figured it out in the end. You need to drop the washers sideways down the hole and then manoever then into position with a screwdriver or somesuch implement BUT you have to remove the stud from the block before dropping the washer into the head. Once the washers are in place you simply pass the stud through the washer and head into the block. Easy when you know how innit! Yes this is correct, but you will also need some vasalline to hold them in place when you lower the head. Link to comment Share on other sites More sharing options...
Jake Posted April 7, 2006 Author Share Posted April 7, 2006 Will KY jelly do? Actually I did the washer thing with the head already mounted on the block. Link to comment Share on other sites More sharing options...
Pete Posted April 7, 2006 Share Posted April 7, 2006 Jake + engine = Hope you sort it... I think he should stick to a Sinclair C5 or something. Link to comment Share on other sites More sharing options...
Jake Posted April 7, 2006 Author Share Posted April 7, 2006 Why? Cos I didn't know how to do something? Did you know how to insert the washers into a VVTi head then Pete? Eh? FFS. Link to comment Share on other sites More sharing options...
Pete Posted April 7, 2006 Share Posted April 7, 2006 Did you know how to insert the washers into a VVTi head then Pete? Eh? Bluetack. Link to comment Share on other sites More sharing options...
Jake Posted April 7, 2006 Author Share Posted April 7, 2006 Free bar was it? Link to comment Share on other sites More sharing options...
Pete Posted April 7, 2006 Share Posted April 7, 2006 Free bar was it? Yep! Ok....talking crap...thinking of a revisit to the bar....burp! Link to comment Share on other sites More sharing options...
