kitchen nightmare take 2!!
black cat
got home last night to find the hot water feed to the washer, which isnt being used has leaked from the end stop union nut.
water under the laminate floor and all has now blown on joints!!!!!!!!
F***in great.. iave only been in 2 weeks.
the trouble is that the stupid chuff that put the kitchen in has built it in round the washer isolation taps so iam gona have to rip the intigrated fridge frezzer to get to the wall taps.
omfg.:(
tt steve
jack of all trades master of none!!!!!!!:D, cheers edd ill get it sorted however iam thinking of giving direct line a call cos ive all on with the rest of the house changed the last ground floor socket front last night and finally got office sorted, Ive resolved the plaster problem. another unit infront of the wall
;) :D :D :D oh yeah oh yeah.......:innocent:
The taps for the WM are behind the integated FF? That must have been a tight squeeze. There's usually bugger all room at the back of Int FFs.
They're easy enough to pull out though mate. (I'm assuming we're talking about a tall FF rather than built-under ones)
Try not to let it topple over and crush you to death as you take it out of the housing though. That'd ruin your weekend.
Makes me laugh with all these kitchen installs, even the so called professionals just slap them in with no regard for getting to anything.
What takes the time is doing everything neatly and going to the trouble of making sure you can get to things if they go wrong without ripping half of it back out.
Blokes at work boast about fitting kitchens in days but they must look shite and be a nightmare should something like this happen.
Paul
by the looks of one corner section the work top has be done by a profesional cos its cut in perfect, however thats where it ends.
also theres no earthing shoud on the extension and conservatory sockets!!!!!
which i am changing. And they have had a down stairs toilet installed upder the stairs (fine) however the consevatory runs across the back of the house there for there is no window to the wc and no vent axia of any type.!!??
this must be ilegal how did it pass building regs???
And did your surveyor not notice the WC thing when you were buying the place?
no no no and no...............????????????? having said that it was only a home buyers survey.:innocent: didnt think it was gona be an issue seen as the building certificate was dated 11 jan 2006..
Surely you can sue someone to get it rectified?:D
i could, but unfortunatly they bought our house cos him and his partner slip up and he down sized.
i know what ive bodged in our house and i ant going there, (most of it is sound ) but the gas fire................ looks superb however has no collor between the unit and the stack!!:sly:
It would depend on when the conervatory was put up- mine is totally illegal now but in 1981 it was fine apparently!!!
the toilet was added 6 months ago ish so has been installed with no vent on purpose, i supose i could pipe poo smells into the floor caverty........
That's a bit risky seeing as....they know where you live!
It annoys me more that surveys etc don't pick up on big things, but they do tell you if your walls are a colour they don't like. :mad:
Exactly! We had a homebuyers and it didn't pick up loads of stuff (too much to go into infact - but it suggested the property could do with a cosmetic uplift) yeah cheers!
