is my stud pattern 114.3?
danwhite
As above really need some new wheels i have found out the offset is 50mm to 48mm lowest .But what stud pattern will be ok on a j spec tt?.
Regards Dan
Dan, have you checked that the wheels will clear the larger 4 pot front calipers? Which wheels are they?
hi mate havent got some yet but need some because 2 of the ones i have are badly bent and i cant drive the car till i find some that will fit.Ive been searching ebay at the mo and just wanted to check with you guys that i was asking the right questions?.
Regards Dan
  • 2 weeks later...
