Front UK Discs (AGAIN!!) - "BluePrint"
Steve W
RE- me other thread . . . .
http://www.mkivsupra.net/vbb/showthread.php?t=63463
was going to just get the Toyota ones . . . AGAIN !
or, the BluePrint (ADL/ADT) ones depending on whichever
way cheaper.
SOOO, priced 'em both, and, the BluePrints were slightly
cheaper.
Went to order 'em, and found only ONE part number ?!?!?
I was SURE they used to be 'sided' ('handed') as they ARE/WERE
identical to the Toyota ones (either Toyota make BluePrint, or,
vice-versa, or, THIRD company made 'em for BOTH ??)
Phoned Blueprint technical and YES, they used to be sided, but
they are altered now to be symmetrical (as any 'normal' vented
disc), have decided to give the latest BluePrint ones a go,
not so much on PRICE (cos there's only ~£6/7 per disc diff')
BUT because AS the Toyota ones warp anyhow, might as well
give these 'new' ones a try ?!?!?
Will post up pics of the OLD BluePrint ones in mo'.....
and pics of the NEW ones tomorrow (left 'em at work
cos haven't decided if ME or THEM to fit - i think i'd
rather 'ave a go meself this time;) )
FatS.
Steve, can you chuck the part number up please as I might need some fronts soon and I use Blueprint but they have lasted sooooo long I've lost the details :D
They are UK spec ones aren't they? :)
Part numbers for the rears would be handy too if you've got them :thumbs:
-Ian
Does this help?? :)
Product Code Price
Fuel Filter ADT32338 £21
Oil Filter ADT32108 £7
Air Filter ADT32246 £25
Clutch Kit ADT330125 £245
Clutch Disc ADT33149 £80
Clutch Cover ADT33262N £110
Release Bearing ADT33324 £35
Water Pump ADT39153 £75
Thermostat ADT39208 £10
Fan Belt ADT39631 £30
Timing Belt ADT37528 £30
Thensioner Bearing ADT37621 £30
Oil Pres. Switch ADT36604 £8
Starter Motor ADT31244 £165
Front Whl Bearing Kit ADT38228 £70
Rear Whl Bearing Kit ADT38315 £70
UJ Kit Front Gearbox ADT33903 £30
UJ Kit Rear Axle ADT33903 £30
UJ Kit Rear Gearbox ADT33903 £30
Stock Spark Plugs PK20R11 £8
Performance SP's SK20R11 £8.50
Iridium BPU Plugs Grde 7 IK22 £10
Iridium BPU Plugs Grde 8 IK24 £10
Iridium BPU Plugs Grde 9 IK27 £11.50
Stock Front Pads ADT34251 £35
Stock Rear Pads ADT34250 £35
Front LH Discs ADT343130C £65
Front RH Disc ADT343128C £65
Rear Discs ADT343120C £120
LH Handbrake Cable ADT346232 £30
RH Handbrake Cable ADT346219 £28
LH Rear Brake Hose ADT353135 £15
RH Rear Brake Hose ADT353135 £15
LH Front Wiper ADT353135 £15
RH Front Wiper ADG09721H £8
Rear Wiper Blade ADG09718B £6
Well, yes, but, those are the OLD part numbers (as i thought i explained ?)
Those TWO have been superceded by ONE ! !
NEW part number is ADT343158
This is the section from the NEW catalogue......
(sorry bit hard to read...had to reduce it to get it under the 244Kb :( )
UK is RIGHT COLUMN
(you can see under the Grey Imports the option of the smaller or
larger discs....)
  • 14 years later...
