UK brakes (again...)
Trig
Bought some UK fronts from Paul E, got a few q's for ya.
- Theyre quite dusty, how do i clean the calipers? Will they need spraying again?
- Im gonna be running the uk fronts with j-spec rears. will this effect the brake bias by much?
- Ive got the calipers, pads and discs with braided lines, will i need anything else to complete the changeover?
- What brake fluid do you guys recommend??
TIA :cool:
erm, brake cleaner:D
its supposed to but lots of people run this set up
shims and pins spring clips etc?
good quality dot 5.1. cant go wrong with toyota stuff
and be prepared to cut the j-spec dust shields off
TIA :cool:
Cheers Lee :cool:
Can i get all the shims, spring clips etc and brake fluid from Mr T??
Trig, these are the parts and part numbers you will need for the front
04945-14110 Toyota Front Brake Shim Kit
04947-14010 Toyota Front Brake Fitting Kit
