carl0s Posted April 6, 2006 Share Posted April 6, 2006 I've been offered a reasonably priced Lower Control Arm, for keeping as a spare, but there's a cut in the boot on the balljoint, which happened when it was removed from the car. Does that make it no good or what? Link to comment Share on other sites More sharing options...
merckx Posted April 6, 2006 Share Posted April 6, 2006 The grease will come out! I've seen some universal boots on Ebay, or try your local motor factors. I would be surprised if you couldn't get another, it's much easier to get a match with the control arm off the car. Link to comment Share on other sites More sharing options...
carl0s Posted April 6, 2006 Author Share Posted April 6, 2006 Well it's £25 including delivery, and the bushes and balljoint itself is good. Link to comment Share on other sites More sharing options...
RobSheffield Posted April 6, 2006 Share Posted April 6, 2006 balljoint isnt removable, so you cant replace the rubber boot, so it will fail an MOT and since they aint the easiest thing to replace, id say NOOO dont do it Link to comment Share on other sites More sharing options...
merckx Posted April 6, 2006 Share Posted April 6, 2006 You don't have to remove the balljoint to fit a new boot! Link to comment Share on other sites More sharing options...
absz Posted April 6, 2006 Share Posted April 6, 2006 balljoint isnt removable, so you cant replace the rubber boot, so it will fail an MOT and since they aint the easiest thing to replace, id say NOOO dont do it the rubber boots on a ball joint are not part of an mot test so theres no problems there. if it was me i'll buy it and you can always remove the boot from the old one to fit on repacking the joint with grease. Link to comment Share on other sites More sharing options...
RobSheffield Posted April 6, 2006 Share Posted April 6, 2006 erm, the rubber boots ARE part of an MOT test actually.... as mine failed on it Link to comment Share on other sites More sharing options...
absz Posted April 6, 2006 Share Posted April 6, 2006 erm, the rubber boots ARE part of an MOT test actually.... as mine failed on it well i must have been doing mot tests wrongly then:sly: Link to comment Share on other sites More sharing options...
RobSheffield Posted April 6, 2006 Share Posted April 6, 2006 well i must have been doing mot tests wrongly then:sly: so if you MOT'd a car, and the balljoint boots had a split in them, you would pass it? Link to comment Share on other sites More sharing options...
absz Posted April 6, 2006 Share Posted April 6, 2006 so if you MOT'd a car, and the balljoint boots had a split in them, you would pass it? yes i would:d the outer cv joint boots and steering gaiters are failures. the ball joints are checked for play and lift. split ball joint boots shorten the life of a component and are advised but not failed. Link to comment Share on other sites More sharing options...
RobSheffield Posted April 6, 2006 Share Posted April 6, 2006 hmm, maybe i had an advisory - so long ago now i forget, it wasnt on the Supra Link to comment Share on other sites More sharing options...
absz Posted April 6, 2006 Share Posted April 6, 2006 all testers have there ways. most testers fail split wiper blades etc but its only a failure if the blade is not clearing the screen properly. nothing to do with a split in wiper blade. but hey thats life. Link to comment Share on other sites More sharing options...
RobSheffield Posted April 6, 2006 Share Posted April 6, 2006 ill come to you for my tests, as my tester on the Supra was an arsehole Link to comment Share on other sites More sharing options...
carl0s Posted April 6, 2006 Author Share Posted April 6, 2006 Frig it. I'll buy it anyway. It's good for spares or selling if someone wants to get uprated bushes installed or something. Good for the money anyway, I bought the other one which is perfect for the same price These lower control arms are ~ £250 from Toyota. Link to comment Share on other sites More sharing options...
LeeT Posted April 7, 2006 Share Posted April 7, 2006 Frig it. I'll buy it anyway. It's good for spares or selling if someone wants to get uprated bushes installed or something. Good for the money anyway, I bought the other one which is perfect for the same price These lower control arms are ~ £250 from Toyota. always handy to have. i have a full set of front and rear suspension arms in the garage. got two of each of most of the rear. Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 7, 2006 Share Posted April 7, 2006 Not wanting to be a smart arse, but why not just remove the boot from your existing wishbone, once the joint is worn (or you bend it... ), and swap it on to your bargain buy spare one when you need to use it? Or is that too easy... Link to comment Share on other sites More sharing options...
carl0s Posted April 7, 2006 Author Share Posted April 7, 2006 Not wanting to be a smart arse, but why not just remove the boot from your existing wishbone, once the joint is worn (or you bend it... ), and swap it on to your bargain buy spare one when you need to use it? Or is that too easy... That's a good enough idea for me! So the boot is detachable then I presume.. Link to comment Share on other sites More sharing options...
absz Posted April 7, 2006 Share Posted April 7, 2006 Not wanting to be a smart arse, but why not just remove the boot from your existing wishbone, once the joint is worn (or you bend it... ), and swap it on to your bargain buy spare one when you need to use it? Or is that too easy... good idea unless the old boot gets damaged in the removal process:D Link to comment Share on other sites More sharing options...
carl0s Posted April 7, 2006 Author Share Posted April 7, 2006 good idea unless the old boot gets damaged in the removal process:D Well, I guess that only happens if you use a ball joint splitter, which I don't think is really ideal or necessary for the job anyway. A large hammer did it for me Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 7, 2006 Share Posted April 7, 2006 Whetehr it's removable (intact) i don't know, but it probably is, with care. There is no need or reason to damage a ball joint boot in splitting the joint if you know how to do it. Carlos seems to have the right idea... Link to comment Share on other sites More sharing options...
