Powersteering noise
Alex
Quote: from ajefford on 4:48 pm on Nov. 29, 2001[br]Mine also does that Alex, i havnt changed a thing since I got
it - but I insisted on a cambelt change.
Its especially noisy at low speeds, at also seems be
worse in colder conditions !
It'll be the pump, they do seem to be a bit iffy, the Soarer uses a similar pump and also suffers noise when they wear. Additives don't really help. They are usually a seal softener for when the rack seals have hardened and started to leak (not necessarily onto the floor, they can leak internally), I doubt an additive will quiten it.
Quote: from Alex Holdroyd on 11:54 pm on Nov. 29, 2001[br]So are you saying I need to replace the pump?
Is there a better, beefier, unit I could try???
My car has covered 90,000 miles so I'll allow it this mechanical failure!!!
No other pump will fit without major tinkering, just get a standard one, same on UK and J-Spec cars AFAIK, so you might get a good used one cheap.
