Rich Posted April 5, 2006 Share Posted April 5, 2006 does anybody know ,will this tyre fit a supra with HKS hypermax suspension with no rubbing issues. anybody got this fitment on their car with low suspension?? thanks, Rich Link to comment Share on other sites More sharing options...
merckx Posted April 5, 2006 Share Posted April 5, 2006 Need to know your wheel width, diameter and offset aswell. What tyre are you running now, if you're using the same wheel you could check to see if a 295 tyre would fit. Link to comment Share on other sites More sharing options...
Thorin Posted April 5, 2006 Share Posted April 5, 2006 How much lower than stock are you? I'd say you're pushing it, but it may be ok. http://www.kulthea.net/fitment.xls Link to comment Share on other sites More sharing options...
cashpoint Posted April 12, 2006 Share Posted April 12, 2006 Rich I tried 295/30 to see what the clearance was like as the garage where i got my tryes from i knew the owner. There were part worns but look like they came to close for comfort to the wheel arches and that was no std springs. Link to comment Share on other sites More sharing options...
Lucifer Posted April 12, 2006 Share Posted April 12, 2006 On stock offset you will need to roll teh rear arches or run 2 degrees of cambre. Link to comment Share on other sites More sharing options...
tbourner Posted April 12, 2006 Share Posted April 12, 2006 I've got 285s and needed the arches rolled. Link to comment Share on other sites More sharing options...
Nic Posted April 12, 2006 Share Posted April 12, 2006 Depends how low you have the ride height and as said wheel dimensions and offset. I have Hypermax II's fitted, but set at a decent ride height for handling/traction, I also have 10" rears and 185/35 width tyres on the back, ocassionally when REALLY pushing it on a corner the tyre will rub the arch. If you set your ride height low then you WILL get rubbing on the arch and you'll most likely get rubbing on the front inner wheel arch lining on full lock. Have a look at the pics in my garage to see ride height Link to comment Share on other sites More sharing options...
cashpoint Posted April 12, 2006 Share Posted April 12, 2006 Nic I'm guessing you ment 285 rather than 185 , Never had a problem with 285 even after i lowered the car. Link to comment Share on other sites More sharing options...
