Matt Harwood Posted November 19, 2003 Share Posted November 19, 2003 I've got a set of stock J-spec springs that you can have, if you want them Roy... Link to comment Share on other sites More sharing options...
Roy Posted November 19, 2003 Author Share Posted November 19, 2003 you da man ! give you a bell in a mo' ...ta Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 19, 2003 Share Posted November 19, 2003 I have a set of used devlopment springs here that would sort you quite well i think. 100 quid for the four, they cost me a LOT more than that, believe me! They will run the car around stock height, but be a little firmer than the UK spec stock ones, and will work OK with your shock absorbers (dampers). Link to comment Share on other sites More sharing options...
Roy Posted November 19, 2003 Author Share Posted November 19, 2003 chris - thank you also, will give you a shout shortly to chat ? Link to comment Share on other sites More sharing options...
Aerotop Dave Posted November 19, 2003 Share Posted November 19, 2003 Is there a lot of difference in the ride quality between UK and J spec? Link to comment Share on other sites More sharing options...
Roy Posted November 19, 2003 Author Share Posted November 19, 2003 i personally found the differences between them to be marginal in everyday use .. Link to comment Share on other sites More sharing options...
