Strut Braces are they any good ?
milocoon
On Ebay you can get these for less than £100 but reading the feedback someone mentioned it was a waste of money ?
I`ve an Aerotop so I do get scuttle shake on the rare day I go topless, would a Cusco Front and Rear improve things slightly / a bit / hugely and could I still fit the roof in the boot ?
Thanks for everybodies feedback !
:search:
Guest Terry S
I would be suprised if the rear makes much of a difference. The front should if you chose a decent one. You maybe better off with the Do-Luck floor bar/brace to help with the flexing
I had Carbing front and rear braces in my old aerotop - made an awesome difference.
Remember that the carbing is a solid, one-piece brace that also bolts to the middle of the chassis at the back, while the cusco is effectively hinged. Who knows if it's measureable the difference in stiffness that either type creates, but it seems obvious to me that the fixed carbing style is going to work 'better'.
as Terry says i think the rear is a waste of time, you realise this when you come to fit it and see the amount of bracing there is once the carpet comes up, this part of the car is built like a battleship, i have one but purely from a bling point of view:D
Ark where can I buy these strut braces from ?
I can supply Carbing and Cusco braces at good prices :)
The Carbing braces are some of the best available, the front ones include a brace, to stop the brake master cylinder flexing, which makes a noticable difference to pedal feel and brake power. The rear ones as mentioned also bolt in the middle to the chassis. They are available in either steel or aluminium. Carbing is also one of the only companies to make a front brace to fit the NA Supra.
I've supplied quite few of these to members, so hopefully someone will be able to post a pic of one fitted.
http://img111.imageshack.us/img111/1130/cimg00014dp.jpg
http://img111.imageshack.us/img111/8629/cimg00025tj.jpg
http://img76.imageshack.us/img76/6040/nafrontalu5zt.jpg
http://img111.imageshack.us/img111/9949/towerbar4wq.jpg
  • 5 weeks later...
I was out in my aero-top today and the discussion of strut-braces came up.
However, I was concerned that on the aero-top a front strut-brace could just end up transfering the cornering force into the middle of the car which is the weaker point...?
You might then feel it flexing more...?
Nope. Used to have one, braced it front and back and it was significantly more solid.
I've found with the carbing front that the car feels more solid and less 'skitish' if that makes sense.
Not so much at low speed where the back will come out due to lack of grip anyway, so the front makes little difference.
Not so much at mega high speed where other factors like aerodynamics seem to take on more significance.
I mostly noticed it at mid speeds, especially over unulating or bumpy roads, where the car now feels more planted and steady.
The feedback so far from members who have fitted the Carbing Brace is very positive. Carbing also make a rear strut and centre floor brace, a combination of all 3 braces sounds like it should make a bit of difference to the stiffness.
Here are a few pics (thanks Chilli :thumbs: ), I have supplied quite a few of these now to members, if anyone would like details please email me at [email protected] and I'll send you a price list.
http://img235.imageshack.us/img235/1011/cimg00015zx.jpg
http://img155.imageshack.us/img155/592/cimg00023ff.jpg
http://img162.imageshack.us/img162/6618/cimg00084ks.jpg
http://img245.imageshack.us/img245/6338/dsc01372small8dq.jpg
http://img364.imageshack.us/img364/6999/dsc01373small7oc.jpg
http://img364.imageshack.us/img364/323/dsc01375small3ly.jpg
  • 1 year later...
  • 1 month later...
anyone have any pics of the NA version of the front and rear struts?
Here you go, as said the front is specifically designed for the NA, the rear will fit an NA or TT. Let me know if you would lie prices
http://img137.imageshack.us/img137/4341/attachmentphpgr9.jpg http://img46.imageshack.us/img46/2775/attachment1phpdh1.jpg
http://img526.imageshack.us/img526/7824/p3150092zg3.jpg
http://img212.imageshack.us/img212/6907/p3310126oh5.jpg http://img232.imageshack.us/img232/1845/p3310127yd8.jpg
Hi Pedrostar,
Short answer is No , the roof fits in, in such a way that it should clear the rear strut(or more accurately miss it as the roof fits in "behind" the strut, rearwards.
Just to clarify though, I do NOT have a rear strut in my Aerotop, only a front Carbring, bought from Nic for around £160 and I can confirm that it makes a noticeable difference!
Rgds
George
