Markie Posted April 3, 2006 Share Posted April 3, 2006 Anyone have some little secrets on getting a supra and its long nose onto a ramp? Or any other lifting tools which may help do the job? Quote Link to comment Share on other sites More sharing options...
colsoop Posted April 3, 2006 Share Posted April 3, 2006 Thick blocks of wood ? Quote Link to comment Share on other sites More sharing options...
LeeT Posted April 3, 2006 Share Posted April 3, 2006 yep as colin said. i use lengths of 4x2" Quote Link to comment Share on other sites More sharing options...
Branners Posted April 3, 2006 Share Posted April 3, 2006 yep, or a couple of bricks. JB Quote Link to comment Share on other sites More sharing options...
mikeyh Posted April 3, 2006 Share Posted April 3, 2006 reverse it on we do this all the time at work with low cars:) Quote Link to comment Share on other sites More sharing options...
LeeT Posted April 3, 2006 Share Posted April 3, 2006 reverse it on we do this all the time at work with low cars:) my car wont go on when reversing either. the front bumper grounds and the front of the sideskirt catches Quote Link to comment Share on other sites More sharing options...
supragold Posted April 3, 2006 Share Posted April 3, 2006 yep, or a couple of bricks. JB I have to drive it half up a curb and half on bricks before I can even get a trolley jack under mine. Quote Link to comment Share on other sites More sharing options...
SimonB Posted April 3, 2006 Share Posted April 3, 2006 I've yet to find a set of normal ramps wide enough for the Supras front wheels, never mind the rear ones. Most are a max width of 210 even for the heavy duty ones. Anyone know where to get some? Quote Link to comment Share on other sites More sharing options...
SupraHuman Posted April 3, 2006 Share Posted April 3, 2006 If you're on your own use a 2x4 if there is another 2 people have them lifting the car by the wheel arches.I(we) done that a few times and works a treat. Quote Link to comment Share on other sites More sharing options...
terribleturner Posted April 3, 2006 Share Posted April 3, 2006 Planks of wood or bricks for me too Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted April 3, 2006 Share Posted April 3, 2006 i can get a trolley uner the diff at the back, but not to the front mount points... i use a scissor jack to get it started at the front, then put ramps/axle stands under it got to do it soon as well, oil and filter change Quote Link to comment Share on other sites More sharing options...
SimonB Posted April 3, 2006 Share Posted April 3, 2006 Look what I found, these look the bollocks. Bit expensive though! Check out the 12ft ones too, luxury... EZ Up ramps Quote Link to comment Share on other sites More sharing options...
SupraJames Posted April 4, 2006 Share Posted April 4, 2006 Simon, I made my own ramps, using scaffold board, heavy duty stuff, cut into 3 different lenghts then just all screwed together with a piece of 2x2 at the end so I know when im on the top step. They are around 10" wide as well, does the job for me, can then use a trolley jack if I need the car higher or need to remove a wheel...!! Quote Link to comment Share on other sites More sharing options...
Markie Posted April 4, 2006 Author Share Posted April 4, 2006 Well, used some timber and got her onto the ramps. Not a huge bit of room to get the CAT on etc, but better than last year... Bolts etc were very dry as you would expect. One of the studs looks a tad worn down. Can I use copper greese on these nuts bolts etc, or should you not use even this on exhaust nuts and bolts.. Quote Link to comment Share on other sites More sharing options...
Mcgoo Posted April 4, 2006 Share Posted April 4, 2006 I've always used it on my exhaust nuts and bolts- does the job. Quote Link to comment Share on other sites More sharing options...
Markie Posted April 5, 2006 Author Share Posted April 5, 2006 i can get a trolley uner the diff at the back, but not to the front mount points... i use a scissor jack to get it started at the front, then put ramps/axle stands under it got to do it soon as well, oil and filter change Rob mate. I always do my filter and oil from inside the engine bay. Just move the power steering res out of the way a bit and its quite easy... Quote Link to comment Share on other sites More sharing options...
