Installing a Oil Catch Can Question ?
soupratt
Hello all,
I havn't seen any Supra in Melb with a oil catch can so I wasn't
quite sure how to install my Greddy unit last weekend. I understand
that it basically needs to sit between the crank-case ventilation
port and air intake pipes before the turbos. Is that correct ?
Looking at the picture of how the system works
http://www.mkiv.com/manual/manualtt/emisson_control_system/ecs3.jpg
I have hooked my unit up between the crank case port on the right
side of the engine (driver's sider) and the intake port (which is
acutally on the 1st turbo intake pipe). This is so the fumes get
caught when the car is turbocharging.
Any ideas if this is correct ? I guess I could have hooked it up to
the PCV valve and intake manifold but looking at the diagram above
this way does not flow when the car is turbocharging and I guess
when most of the blow-by gas forms.
Thanks
Andrei
