Shovels Posted April 1, 2006 Share Posted April 1, 2006 Hi Guys, I've just done some work on my Peugeot 306 and I need to spray a couple of small areas. I've prepped the area by filling and sanding down. I'm going to spray first with a primer, but when it comes to spraying the colour I know I should do thin coates, but should I rub down with wet and dry inbetween? Same with the laquer, is it ok to sand with wet and dry if I fluff up a coat - or will it just go dull? I sprayed a couple of things before and I can never seem to get a shiney finish. Any tips??? Quote Link to comment Share on other sites More sharing options...
SupraJames Posted April 1, 2006 Share Posted April 1, 2006 Just take your time, get the surface as clean and as smooth as poss, paint wise yes very thin lights coats, if you rub them down between coats be very gentle or you will take off what you just put on. Laquer again thin coats but leave them to dry totally before putting the next one on. Never rubbed down laquer coats myself, so not sure if you can or not.! Quote Link to comment Share on other sites More sharing options...
Shovels Posted April 1, 2006 Author Share Posted April 1, 2006 cool, gonna give it a go tomorrow morning. Fun fun fun! Quote Link to comment Share on other sites More sharing options...
Fifty Posted April 1, 2006 Share Posted April 1, 2006 Strange I have a 306 as well; you can come to the meet in it lol Rich:p Quote Link to comment Share on other sites More sharing options...
Shovels Posted April 1, 2006 Author Share Posted April 1, 2006 sure.... I'll just park it a mile away and walk in Quote Link to comment Share on other sites More sharing options...
Fifty Posted April 1, 2006 Share Posted April 1, 2006 Lol you could pretend to be an ordinary traveller lol Rich Quote Link to comment Share on other sites More sharing options...
Shovels Posted April 1, 2006 Author Share Posted April 1, 2006 lol... You saying I'm a pikey! Quote Link to comment Share on other sites More sharing options...
Fifty Posted April 1, 2006 Share Posted April 1, 2006 no lol I meant just like an ordinary person calling in the services lol Rich:p Quote Link to comment Share on other sites More sharing options...
Shovels Posted April 1, 2006 Author Share Posted April 1, 2006 lol, going car hunting with the misses tomorrow now, but if we're passing around 2 I'll probably pop up and ponder over. Quote Link to comment Share on other sites More sharing options...
Fifty Posted April 1, 2006 Share Posted April 1, 2006 Ok 52 Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted April 1, 2006 Share Posted April 1, 2006 finish off your sanding with 120 grit paper, then apply even coats of primer,using a black or dark coloured aerosol lightly spray over the primer as a guide coat. using 800 grit wet and dry wet flat the primer with the paper and a flatting block (your hands are not flat) dry off and spirit wipe clean. if you are blending the colour and not doing a whole panel use scotchbrite and rub around the area were you want to blend. spirit wipe again and mask off ready to spray. spirit wipe again and apply light but even coats until covered. hope this helps Dave :-) Quote Link to comment Share on other sites More sharing options...
