Hi everyone, (HELP NEEDED)
Guest NicoTT
Guest NicoTT
I've just brought a supra import tt ...
I'm currently loving it and i don't know why i didn't buy one sooner
However she is low on oil and im not sure whats the best to buy??
Any help would be great..
10W40 is what Toyota recommends. You can put other fully synthetic oils in it if you like. eg the Silkoline CJ mentioned.
Do you know when the oil was last changed? If not you should change it. The turbos on these cars need a good supply of decent oil.
I forgot to mention that mine is running BPU hence the slight difference in reccomendations.
Guest NicoTT
She's completly standard and well in need of a few quid spending.
I also need advice for where i can get a de-restriction? and maybe a good check over and service in the west midlands area?
Of the people I know, I would think the closest to you would be either Chris Wilson or Turbo Fit at MK.
