Registered Nutter Posted December 6, 2001 Share Posted December 6, 2001 Was wondering what implications there are from the removal of the trac fuse as in will it effect my RLTC at all? also is it best to remove the fuse or to unclip the wire to disable it? Will this disable the top speed limiter? do i have a top speed limiter on a j-spec anyway? Quote Link to comment Share on other sites More sharing options...
Gareth Davies Posted December 6, 2001 Share Posted December 6, 2001 The J-spec limiter is a lot lower than even the UK spec, but it will probably have been changed or removed. I didn't even think a J-spec had a trac fuse! But if you have one that has any effect then it won't harm the RLTC at all (infact it's a good idea to remove it). I think there's some ongoing concerns about the effect on the gearbox changes though. Quote Link to comment Share on other sites More sharing options...
Branners Posted December 6, 2001 Share Posted December 6, 2001 Is this on an auto or manual? Almost no implications when removing it on a manual, but with the auto it does affect the gearchanges by making them more severe which can in the very very long run possibly maybe damage the gearbox, but its difficult to say whether it will shorten the gearbox life by 10 miles or 10,000 miles. My approach would be to remove it if you can put up with the flashing dashboard light and accept that the gearbox may not last the whole lifetime of the car...or then again it might. JB Quote Link to comment Share on other sites More sharing options...
Registered Nutter Posted December 6, 2001 Author Share Posted December 6, 2001 It is a manual went and tried it in my lunch break and there is a limiter i dont mean the 112mph one. when it comes on the hazzard lights light comes on and stays on for 5 seconds or so. Quote Link to comment Share on other sites More sharing options...
