Engine Diagnosis
cg084
Hi all,
Thouroughly pleased with my Supra SZ import. Picked it up today. Only problem now is that the engine diagnosis light the little orange one on the left to the right hand warning cluster is now iluminated. Any ideas on what it may be.
It does not come on all the time. Only some times. Does not light up straight away either.
Just had a thought. When i filled the car up after collecting it i filled it with Normal Unleaded and not super unleaded. Unsure whether that would make a difference.
Also i could do with a users manual for the car just so i have got something to refer to if needed.
Any help mostly appreciated.
Grinning like a cheshire cat now.
Give us some more clues ! !
Does it 'do' anything before the ENGINE MANAGEMENT light
comes on (the orange 'engine' piccy ??)
Any sounds ? Does the Warning Triangle come on too ?
It can be something really..... OR SOMETHING REALLY BAD ! !
DON'T KEEP MAKING IT COME ON 'TILL YOU KNOW ! ! ! ! ! :(
FatS
if your supra has been converted to display MILES on the odometer then it is quite possible that the diagnostic light will flash in a certain pattern or it will come on at certain speeds . This means that the conversion has been done incorrectly , if this is the case you're in luck as i know all there is to know about this part of the supra having just investigated the whole dubious procedure..
get back to me if you want
alanB
alanB
