Front Discs - choices....AGAIN ! !
Steve W
YES i KNOW it's asking the same old question,
just didn't find a definitive answer in the other threads !
UK size front disc's (sorry, ROTORS !)
Makes ?
Toyota,
3G
DBA
Prices ???
Is the consensus that the Toyota disc's are relatively easy to warp ?
Which of the others DEFINITELY DON'T WARP ! ! ??
[Any downsides to the 'other' make disc's ???]
Thanks, Steve.
I'd be interested in the answer to this one too as I've just scored myself a set of GT4 205 calipers.
I'm inclined to go for the 3G GR-10 that Paul does - price is right LOL!
Do the ST205 calipers bolt straight on in place of J spec brakes front and rear? Then just use Supra discs?
Cheers,
Brian.
On UK brakes the stock Toyota discs are as good as it gets until you go to separate bells with a lightweight race disc. On J-Spec brakes i again firmly believe that the stock discs are as good as it gets. The fancier the box, the more funny grooves, or the more bizarre the coating on the discs the more *rap they are, in my experience.
Any actual justification for this opinion mate? Have you had fancy coated, multi-groved discs and found them to perform worse than standard???:)
Yes, most of them are based on Taiwanese or Chinese castings, that are soft as whatsit, out of balance, and poorly machined. The ones with holes nailed in them are even worse. A genuine Toyota disc has balance weights, if needed. El Cheapo ones are just finish machined and core shift in the (bad) castings means they can be wildly out of balance.
So, if the Toyota ones are best, and, i've warped 'em on an N/A doing
fairly mundane speeds (these are UK brakes BTW), there's no better choice ??
Why would the Soop eat discs like that then ??
There are much heavier cars just as fast (as my N/A that is !) and our
discs are pretty substantial....aren't they ??
No solution ??:(
[and it's not like they're even CHEAP ! ! !]
Am I right in thinking that one of the common reasons for warping is having the brakes applied onto hot disc. The cooling down of the disc is not uniform because the pads applied to the disc surface will affect the uniform heat disipation. This puts extra stresses on the disc around the affected area and results in warping...?
*waits to be corrected ;) *
No solution ??:(
Were the discs definitely genuine Toyota parts Steve? What pads were you using? Are you sure it is the discs that are warped and not a wheel bearing that is worn? You'll feel a vibration under braking if your bearing is shot, that could be mistaken for a warped disc.
Question you CW the Jedi Master, you will? Much to learn young Padiwan he has :p
Yes Nic.
Toyota discs and pads (fronts AND rears)
must admit do need to just check bearings but drives/cruises fine,
it's only under braking (and not even very hard braking).
It was only under braking that I got a vibration from the wheel bearing on mine, if it's coming from the nearside front, then could well be a bearing is shot as a result of kerbing.
KERBING !? !!?
Don't you start swearing at ME ! ! :tongue:
:D Not US mate, but possibly previous owner,
but it's been fine past ~5months
(he may have 'started' it off though 'spose)
:fool: krap that's 2 stupid spelling mistakes in the last few minutes, I need another :burp:
I have never ever had to change a stock disc through waeping, they seem fine, if you buy some temperature paint from somewhere and get a reading about how hot the discs are getting i can give some meaningful advice. The stock pads are not suitable for other than normal road usage, there are other, far better, options if you are pushing the envelope with stock brakes.
I can well understand the 'cheap' bit mate but not so sure on the 'fany' ones being crap as well - surely if you're paying a fair wedge then the discs should relflec this?? I personally would never use cheap discs but would like to know why I shouldn't use (more expensive) 'fancy' discs??
More expensive does not always mean better...
Quite so, the question I am trying to get answered is "Why not?" What is the problem with other discs in their fancy boxes? What is it about their design that makes them perform worse than the stock Mr T discs?
