Steve Gee Posted December 6, 2001 Share Posted December 6, 2001 My Cruise control won't take work over 72MPH. Not that I ever exceed the speed limit officer!!! Any suggestions? Thanks Steve Quote Link to comment Share on other sites More sharing options...
Guest Ash Posted December 6, 2001 Share Posted December 6, 2001 Common problem. Solution is to feed the cruise-control ECU with the same divided signal currently feeding your speedo. ECU is located behind the instrument cluster. You will have to grovel from underneath to get to it. Wire is pink with silver band, 7th in from left (looking at back of socket). After conversion, cruise will operate from about 40 to 120 mph. Yours, J Quote Link to comment Share on other sites More sharing options...
