high level break light
NeoFuture
It's BRAKE light, mate. :D
It's a common fault. The LEDs are a PITA to change/difficult to get the right ones. I think Emin changes about £50 exchange to do a proper job or Nic (IIRC) sells new ones for about £80. I got lucky and found one a scrapyard for cheap.
If you've got a group of 4 out then it will be a damaged track on the circuit board. especially if they are at either end, or dead centre, where the screws go through. I split mine carefully using a dremmel circular saw and soldered a wire to replace the damaged track, then resealed with clear silicon.
Good post, but damn... wish I'd know that 2 years ago! Would have saved me £80 getting a replacement.
